BC type
Old   July 10, 2009, 03:19
Default BC type
Kyian Barrat
Khelian973 is on a distinguished road
Hi foamers,
I have a stupid question but i dont know the answer. I have an interface between a solid and a fluid, considered as a wall.
What is the "type" to implement a simple wall, allowing the heat flux of temperature, in both side. "ZeroGradient" is for adiabatic wall i know. "fixedValue" doenst fit. I uses the type "calculated" but im not sure.
There are solidWallTemperatureCoupled or solidWallHeatFluxTemperatureCoupled but im not understand exactly for what case these both patches are necessary.
Thanks for helping me
SIncerely
Kyian
Khelian973 is offline   Reply With Quote
Old   July 10, 2009, 05:10
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
The first question that comes to mind is: Which solver are you using? Any further discussion depends on this. And please be more specific in the title when you start a new thread. For instance "BC Type for Heat Flux". BTW: if you search for that phrase you will find some threads that might be of interest for you
gschaider is offline   Reply With Quote
Old   July 10, 2009, 05:49
Kyian Barrat
Hi Bernhard
Sorry dor the tittle , i will try to be more specific next time...
Im using the solver chtMultiRegion foam. I have a hot fluid in a pipeline and I want to study the impact of the heat transfer from fluid to the solid.
I've read some thread about BC for heat flux but it's usually to have a fixed heat flux. It's just a simple interface between a fluid and a solid allowing heat transfert
Old   July 10, 2009, 07:55
Assistant Moderator
Bernhard Gschaider
Hi Bernhard
I never worked with the cht-solver so I'm afraid I can't help you there. Sorry.
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
LiftDrag tool nuovodna OpenFOAM Running, Solving & CFD 45 September 2, 2009 17:56
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 05:49
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
