July 30, 2010, 13:44 |
Help Required With Simple Test Case
Rep Power: 15 |
Hey everyone,
Firstly while I have several years of experience with Fluent I am completely new to OpenFOAM and have had a hard time getting my head around the framework of the program. If someone could help me set up the following case I would be most grateful! I want to set up a 500m x 25m 2-D structured mesh with 1m^2 cells as a transient, incompressible case (icoFoam ?) with (in Fluent-speak) a velocity inlet, two periodic faces and a pressure outlet. The velocity inlet has been prescribed with a user-defined function in Fluent and I could use some help implementing this in OpenFOAM also. Later I will introduce some objects in the flow field and go to 3-D etc. but if I could get some help to start up this simple case asap then that would be great. Thanks! |
July 30, 2010, 13:55 |
Your case seems simple to setup in OpenFOAM. The best option to prescribe your user-defined function in the inlet is to use the groovyBC utility that is available in the OpenFOAM wiki. Regards, Jose Santos |
July 30, 2010, 14:43 |
Rep Power: 15 |
Thanks for that tip! Off-topic but I'm doing some cleaning right now as my room is a mess so I'll look into this groovyBC facility tomorrow!
I want to specify fluctuating u and v components though, rather than just an oscillating velocity magnitude normal to the inlet boundary. I've found this test case... http://openfoamwiki.net/index.php/Bl...Flow_Benchmark ...which is something like what I'll ultimately be doing. What I'll try and do is go as far as I can on my own modifying this code and when I come across problems I'll hopefully have more specific questions. Thanks again! |
July 31, 2010, 19:58 |
Rep Power: 15 |
OK, I've managed to set up the case apart from my inlet BC...
August 3, 2010, 08:45 |
groovyBC
Rep Power: 15 |
Last edited by steph79; August 4, 2010 at 13:19. Reason: Problem solved on other topic! |
Display Modes | |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 19:46 |
Test Case for testing numerical dissipation | Flo | Main CFD Forum | 6 | January 25, 2008 13:35 |
Porous Media test case | Alex | FLUENT | 0 | April 9, 2006 09:23 |
Test Case | ganesh | Main CFD Forum | 0 | March 16, 2006 13:34 |
