Problem with decomposePar tool
Dear Openfoamers,
I have a problem while trying to decompose one of my cases in order to run it in parallel. In this case, I have a cyclic patch which seems to be the problem even if I already used such patches in other cases without any problem. Here is the output of decomposePar: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-53b7f692aa41 Exec : decomposePar -case coarse/ Date : Oct 23 2009 Time : 14:58:57 Host : shagwell.rtech.fr PID : 29311 Case : ./coarse nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Time = 0 Create mesh Calculating distribution of cells Selecting decompositionMethod hierarchical Finished decomposition in 0.1 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Calculating processor boundary addressing Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 6826 Number of faces shared with processor 2 = 810 Number of faces shared with processor 1 = 812 Number of processor patches = 2 Number of processor faces = 1622 Number of boundary faces = 1596 Processor 1 Number of cells = 6826 Number of faces shared with processor 0 = 812 Number of faces shared with processor 3 = 817 Number of faces shared with processor 2 = 114 Number of processor patches = 3 Number of processor faces = 1743 Number of boundary faces = 1909 Processor 2 Number of cells = 6826 Number of faces shared with processor 0 = 810 Number of faces shared with processor 3 = 1097 Number of faces shared with processor 1 = 114 Number of processor patches = 3 Number of processor faces = 2021 Number of boundary faces = 1215 Processor 3 Number of cells = 6826 Number of faces shared with processor 2 = 1097 Number of faces shared with processor 1 = 817 Number of processor patches = 2 Number of processor faces = 1914 Number of boundary faces = 902 Number of processor faces = 3650 Max number of processor patches = 3 Max number of faces between processors = 2021 Point 180of point-pair 36 is a global point but the other point 36 is not From function cyclicPointPatch::calcGeometry() const in file meshes/pointMesh/pointPatches/constraint/cyclic/cyclicPointPatch.C at line 139. FOAM exiting I would like to know what is a global point with respect to a non global one? Where could be the problem? Is there a solution with OpenFOAM tools or is changing my mesh the only solution? Thanks for any help, I am getting crazy with this! Regards, Vincent |
This may be of absolutely no use to you, but did you run renumberMesh before decomposing?
Hi FOAMers,
I also have some trouble with decomposePar. I'm trying to decompose a big tube mesh to run simpleFOAM on it. When exectuing decomposePar I get this message: Quote:
I don't know, why a "value" entry is expected, I don't want the wall to be a fixed value. Any help is appreciated. |
For your boundary condition type, this value can be pretty much anything in the 0/ boundary condition files - ie, zero is often a good enough value to blindly hack in. At later timesteps, the 'value' entry will contain the values calculated on the boundary patch. Even if your boundary condition is smart enough to determine the correct wall values itself, you will need the 'value' field later on - eg, during post-processing or visualization. These components likely don't know anything about how your boundary condition works and may not even have access to any OpenFOAM libraries. |
Hi Mark,
thank you for your help. I applied for every "wall" boundary in the 0/R file "type fixedValue; value uniform (0 0 0 0 0 0);" and now I could run decomposePar on the case. But I still don't realy understand it. Before, I have declared the "wall" boundarys with "kqRWallFunction". I actually thought, that this would be the correct way to declare the initial conditions for R. |
If you look at the tutorials/multiphase/interFoam/ras/damBreak/0/R you'll see that you want something like this: Code:
internalField uniform ( 0 0 0 0 0 0 ); If you do both, the 0/R file would be a bit more compact: Code:
internalField uniform ( 0 0 0 0 0 0 ); /mark |
Hi Mark,
thank you very much, that really helped!! I think, that I've got the point. |
GlobalPoint?
Hello everybody,
I have the same problem of Vincent after running decomposePar: Quote:
face 294 and 7426 areas do not match by 0.0154922% -- possible face ordering problem#0 Foam::error::printStack(Foam::Ostream&) in "/root/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" What is going wrong? Any idea? mad |
Global Points for a Single Processor Job?
Can anyone answer the original question posted by Vincent:
>Point 180of point-pair 36 is a global point but the other point 36 is not > >From function cyclicPointPatch::calcGeometry() const >in file >meshes/pointMesh/pointPatches/constraint/cyclic/cyclicPointPatch.C at >line 139. > >FOAM exiting > > >I would like to know what is a global point with respect to a non global >one? >Where could be the problem? Is there a solution with OpenFOAM tools or >is changing my mesh the only solution? I am having a similar issue but for a serial job. My simpleFoam case runs to completion, but when I try to run foamToVTK to view the results in paraView, I get the error: Point 62of point-pair 46 is a global point but the other point 63 is not From function cyclicPointPatch::calcGeometry() const in file meshes/pointMesh/pointPatches/constraint/cyclic/cyclicPointPatch.C at line 139. FOAM exiting What is a global point? I thought global points had to do with parallel processing. My job is serial. Rob |
I had the same problem as you describe, see my previous post. I guess the problem is due to how the points are numbered. First try the renumberMesh utility and than run paraFoam, it worked for me some time ago. If you get an error, try the following work-around: copy the time step you want to check and the constant folder in a new case folder, redefine the cyclic patches as symmetryPlane, and than run paraFoam. Of course, the problem is not solved, but at least you can see your results! Hope it helps, cheers, maddalena |
Everything is ok, if those patches are not "cyclic" but "symmetryPlane". However, when I change them into "cyclic", everything is not ok. It is the same as above error informations. How can I do it?
Hello Sandy,
the workaround I proposed above is useful only to see your results after a successfull converged single processor run. At that point, you do not need the boundary type definition, and symmetryPlane is used only as a postprocessing information. Hope to be clear. Bye maddalena |
Hi, I could not understand your meanings very well, however, I have solved my problem by using "preservePatches" in decomposeParDict. But I don't know why my simulation case oscillates so much? I guess it is very difficult to get convergence to the cyclic BC .... |
Well... copy paste constant, system and latestTime folder in a new folder, than replace the word cyclic with symmetryPlane for every occurrence inside the boundary file and in p, U, epsilon, k, ... files.
Yes, maddalena, maybe you are right, maybe not. I ever simulated natural convection problems. Their results are very very easy to be effected by initial fields. Different initial fields sometimes will get different final-results. It looks reasonal and not logical, and I felt so strange too, but it is the fact. .... So, now I always hesitate to begin from the first step, if I change the BC seriously .....
Sure, your method should decrease the initial osicillation. I will try. Thanks. |
:D:D YES, dream the pie in sky ... Thanks, anyway!!
Ok, it's an old thread, but I ran into the same problem. I can share my solution, perhaps it helps anybody who faces the problem again. It looks like in my case that the 2 periodic patches (that make up the cyclic patch) do not exactly match. In my case, the maximum mismatch is in the order of 10^-7. The strange thing is that with this small mismatch, checkMesh does not report an error and the simulation can be run in serial. Problems only arise when you try to visualize the results or decompose the case for a parallel simulation.
I solved it by manually dividing the cyclic patch in the constant/polyMesh/boundary file into two equally sized patches called Periodic1 and Periodic2. Then I merged them again to one cyclic patch using createPatch. The createPatch utility makes sure that the new cyclic patch is matching both periodic patches and the numbering is correct. Also the reported post-processing problem disappeared. |
