timeVaryingMappedFixedValue
hi,
I am using simpleFoam k-e model. I want to use the data from the experiment for the inlet velocity, inlet k and inlet epsilon. As I understand I should do like the tutorial pitzDailyExptInlet: constant/boundaryData/inlet/points defines the points where the experiments data are collected. And constant/boundaryData/inlet/points/0/ gives the corresponding value for U, k, epsilon. my first question is : If my experiment data for U are collected at different points as those data for k and epsilon, how should i edit "constant/boundaryData/inlet/points" ---------------------------------------------------------------------- What I did till now is to leave the k and epsilon to be uniform fixed value and just give U in constant/boundaryData/inlet/points/0/. I got the following error when I run the case: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U DTRIS2 - Fatal error! Fails for point number I = 9 M = 8 M1 = 9 X,Y(M) = 0 0.9375 X,Y(M1) = 0 0.9375 #0 Foam::error::printStack(Foam::Ostream&) in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Vector<double> >::interpolate(Foam::Field<Foam::Vector<double> > const&) const in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #4 Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Vector<double> >::checkTable() in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Vector<double> >::updateCoeffs() in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #6 Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Vector<double> >::timeVaryingMappedFixedValueFvPatchField(Foam::f vPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #7 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::timeVaryi ngMappedFixedValueFvPatchField<Foam::Vector<double > > >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #8 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/simpleFoam" #9 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/simpleFoam" #10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/simpleFoam" #11 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/simpleFoam" #12 main in "/amd/software/linux64/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/simpleFoam" #13 __libc_start_main in "/lib/libc.so.6" #14 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 Segmentation fault (core dumped) ------------------------------------------------------------------------- In my case the number of experiment data is less than the number of grid points. But I don't think this is a problem. Any suggestion is welcome. Thanks |
I have worked with timeVaryingMappedFixedValue and have seen this error many times. I suggest you switch on the Debug Flag for timeVaryingMappedFixedValue and post the result of a similar run here.
These errors are often related to the distribution of your points. |
Thanks Sebastian. where can I switch the debug flag on?
It is located in ~/OpenFOAM/OpenFOAM-1.x/etc/controlDict I'm currently not working in my Linux environment, so I can't tell you exactly how this file looks like, but you should search for the entry timeVaryingMappedFixedValue and change the following 0 to 1 for switching on the debug flag. If you then run the case you will get some more detailed error description. Simply post the result here and we will have a look into it. |
