icoFoam >> density >> kinematic viscosity for air 20°C
Old   November 30, 2009, 04:19
Default icoFoam >> density >> kinematic viscosity for air 20°C
Markus Golbs Hamm AG
mgolbs is on a distinguished road
I want solve a problem whis air by 20°C in profile whis turbulent flow and icoFoam. Where can i set the density of air and the kinematic viscosity? Is the k/e-Modell in icoFoam use for turbulent flow?
Greeting Markus
mgolbs is offline   Reply With Quote
Old   December 1, 2009, 07:00
Gijsbert Wierink
gwierink is on a distinguished road
Hi Markus,
You can set nu in constant/transportProperties.
Regards, Gijs
gwierink is offline   Reply With Quote
Old   December 1, 2009, 10:23
thank's! I have a problem, because icoPipe is only for laminar flow. I need turbulent flow. Also I must use simplefoam. The are any parameters to set:
# Field Patch Field Type
U ......................
p ......................
k ......................
epsilon ......................
R .....................
nuTilda .....................
Which physical properties to allocate U, p, k, epsilon, R, nuTilda and which physical quantity?
Greeting Markus
Old   December 1, 2009, 13:50
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Hi Markus,
Use simpleFoam if you want steady-state, or pisoFoam for transient flow.
I would recommend you to start by looking in the OpenFOAM user guide, there you have a couple of tutorials on setting up turbulent cases.
Good luck,
Jose Santos
santos is offline   Reply With Quote
Old   December 2, 2009, 10:52
thanks for the informations. In the openFoam userGuide are importent dokus. I have solve a modell whis icoFoam, linear flow. This works well. The same modell I would like the same mesh solve whis simpleFoam.
Is pisoFoam under 1.4.1 not available?
Where can I set the density of flow medium?
The definition of boundary in simpleFoam are likewise icoFoam.
# the wall surfaces are set to wall >> the paremeter from U, p...nuTilda are constants? When no, where can I manage this parameter, in asci File?
# the Flow input surfaces are set to inlet >> the paremeter from U, p...nuTilda are also constants?
# the flow output surfaces are set to outlet. >> the paremeter from U, p...nuTilda are also constants?
Under point Fields (simpleFoam) are the parameter U, p, k, epsillon, R, nuTilda.
# Is U the flow velocity in X,Y and Z direction?
# Is p the pressure in SI Unit?
# What is k - the thermal conductivity or k=1/2(Ux²...)?
# What is epsillon for a physical value epsillon=C...^0.75.../l?
# What is R for a physical value - Reynolds Stress?
# What is nuTilda for a physical value?
About informations I'm very happy!
Greeting Markus
Old   December 2, 2009, 12:28
santos's Avatar
Jose Luis Santos
In 1.4.1, pisoFoam=turbFoam.
You don't need to set the density for an incompressible fluid, you just set the kinematic viscosity=viscosity/density in the constant/transportProperties of your case.
Regarding the boundary conditions and initial fields, you can look in the tutorials available on how to set them (cd $FOAM_TUTORIALS && ls).
The answer to all your remaining questions are in the User Guide, I suggest you to study it in detail.
Regards,
Jose Santos
Old   December 2, 2009, 12:37
Gijsbert Wierink
Hi Markus,
Here some short answers. I think pisoFoam in OF-1.6 is like turbFoam in OF-1.4.1, an incompressible transient solver.
You can set U, p, etc in 0/.
k is the turbulent kinetic energy k = 1/2 (u')^2
epsilon is the dissipation rate epsilon = C_mu^0.75 * k^1.5 / L, where C_mu is usually 0.09 and L is, say, 20% of channel width.
This stuff is explained in section 2.1.8.1 of the user guide.
The dimensions of p depend on the solver, but they are SI anyways: [kg m s T n A cd], so [0 1 -2 0 0 0 0] means m/s^2.
Hope this helps!
Regards, Gijs
Old   December 2, 2009, 12:39
Gijsbert Wierink
Oh yeah, forgot, you can set the density in constant/transportProperties by changing the kinematic viscosity nu (which is the dynamic viscosity mu divide by density) ...
Regards, Gijs
Old   December 4, 2009, 02:25
thanks for the many Informations. I have a look in the userGuide.. but not all my questions are answered.
When I create a modell "90° pipe" -turbulent air, whis wall, one input 10m/s y-Direction, and 100 Pa relativ, one output whis 0 Pa relativ medium air 20°C and I searching "distribution of pressure" and "distribution of velocity" in the "90°pipe" what must I set leastwise in turbFoam?
The output after solving "pressure" are "static pressure" or "velocity head" or "velocity head and static pressure"?
Greeting Markus
Old   February 11, 2010, 05:00
....k is the turbulent kinetic energy k = 1/2 (u')^2
epsilon is the dissipation rate epsilon = C_mu^0.75 * k^1.5 / L, where C_mu is usually 0.09 and L is, say, 20% of channel width....
Is k and epsilon only to set in internalField, or also in inlet and outlet faces?
Greeting Markus
Old   February 13, 2010, 02:50
Gijsbert Wierink
Hi Markus,
You need to set k and epsilon at the inlet, outlet, as well as for the internalField. You could set k and epsilon according to the equations above and then the internal field to 0 or something small (e.g. 1% of inlet value).
Regards, Gijs
Old   February 15, 2010, 10:09
thanks for the informations. My mistake was setting "0" in the internal field of k and epsilon.
Greeting Markus
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
User-defined turbulent viscosity - kinematic or dynamic? tstorm FLUENT 0 August 13, 2009 16:49
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 12:55
Warning 097- AB Siemens 6 November 15, 2004 04:41
