-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   setFields doesn't function for a tetrahedral mesh - interFoam (http://www.cfd-online.com/Forums/openfoam-pre-processing/74993-setfields-doesnt-function-tetrahedral-mesh-interfoam.html)
tommie April 13, 2010 18:24
Hi everyone,
I want to set up a interFoam case and I have problems to get running setFields.
I definite a box:
regions
boxToCell
box (0 0 -1) (0.5 0.5 -0.5);
fieldValues
volScalarFieldValue gamma 1
After executing nothing happens.
I tried to create a box with cellSet (via cellSetDict). It also fails.
I created the mesh with salome meca. Imported via ideasUnvToFoam. The mesh contains of tetrahedrons.
If I install and use funkySetFields could be that a solution?
Thanks for all hints and comments.
Tommie
sega April 14, 2010 13:57
I would give it a try. funkySetFields is a very useful contribution!
alberto April 15, 2010 01:08
Could you post a small simple case where it doesn't work?
Best,
tommie April 15, 2010 03:06
I installed funkySetFields in 1.5-dev and now it works!!
My congratulation to the developer of funkySetFields.
It's a very good contribution.
(funkySetFields -time 0 -field gamma -expression 1 -condition "pos().x <= 0.5 && pos().y <= 0.5 && pos().z >= -0.5")
After executing funkySetFields I had to reconfigure boundary conditions of gamma- dict (walls, inlets, inletOutlets ...)
On my system setFields together with dam break tutorial works.
But it doesn't work if I create a tetra mesh with Salome Meca 4.1.4 (approx 250.000 cells) and import this via ideasUnvToFoam.
alberto April 15, 2010 03:28
Maybe you can report a bug and provide a test case.
Best,
holger_marschall April 15, 2010 03:32
Hi Tommie,
Credit goes to Bernhard Gschaider :)
Add -keepPatches to your line, and no reediting of these files is needed...
Would you provide a minimal working example? (We still would like to know were the problem takes its origin.)
best,
Holger
