How to create BCs?
Beginner's question:
I have created the STL- geom and imported it by using snappyHexMesh. sHM worked well, but how do I get the boundary conditions to OpenFoam? => I used DISCRETIZER, but that didn't work very well. |
If you use discretizer-setup.
After you created the snappyHexMesh. Reload that mesh and then choos a solver (simpleFoam etc). Now you can create BC:s. Björn |
Hi Jörg,
You can have a look:
http://www.discretizer.org/node/14 last video shows an example of applying BC:s Regards Björn |
Hi Björn,
Discretizer looks nice! Thanks for the effort! |
Got it!
Thank you Björn and gwierink (what ever that means)!!!
Morning has broken and sim got runnin'. YaYaYa!!! Thanks for discretizer! Nice tool - but manual is needed! (Steps were: Geom in Pro/E=> STL with Pro/E => Editing STL manually (separating inlet/outlet faces) => creating mesh under DISCRETIZER with snappyHexmesh => creating BCs with DISCRETIZER => starting and viewing sim) Jörg |
Hi Jörg,
Good to hear things are running! Quote:
I'm setting up an external aero case as a tutorial.
