how to set the inlet as non-uniform?
Old   June 22, 2010, 14:48
Default how to set the inlet as non-uniform?
Benni
egerland is on a distinguished road
I run my case with a fixed value at the inlet velocity field. Now I want to have an function of the velocity at the inlet. Is there any utility to set the inlet velocity field variable?
Can anybody help me?
Thanx
egerland is offline   Reply With Quote
Old   June 23, 2010, 04:20
Nima Samkhaniani
nimasam is on a distinguished road
use groovyBC which you can find in wiki
nimasam is offline   Reply With Quote
Old   June 29, 2010, 03:51
Question Non-uniform flow distribution
Aurel is on a distinguished road
Hi together,
I would like to simulate a non-uniform flow distribution (swirl) at the inlet of a diffuser. FunkySetFields is already installed on my computer.
Sadly I do not have any idea how to modify the case in order to run the program with a non-uniform flow field.
Does anybody have an advice or a recommendation like a tutorial or an example in order to get an imagination how it works? The “contrib FunkySetFields” in the openfoamwiki is already known.
In advance many thanks
Marc
Aurel is offline   Reply With Quote
How to set pulsating inlet boundary conditions with a very high frequency Ton CFX 10 March 22, 2012 17:57
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Non uniform Inlet BC kyubi OpenFOAM Post-Processing 2 June 16, 2008 09:31
how to set inlet BC for using preconditionin Michel Main CFD Forum 0 October 23, 2007 05:56
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 13:32
