rotatingWall with interFoam
Old   November 20, 2010, 12:14
Default rotatingWall with interFoam
H. Melles
HenningHAW is on a distinguished road
I would like to use the rotatingWallVelocity BC with the interFoam solver to simulate a kind of centrifuge.
In */0/U I set for my rotatingWall patch
type rotatingWallVelocity;
origin (0 0 0);
axis (0 0 1);
omega 18;
The solver seems to run without problems but if I watch the results in Paraview, the rotating Wall has no effect to the fluid. But when plotting the velocity of the rotatingWall - patch everything seems to work. The connection between wall and fluid in not working.
So, what is my mistake??? Is there a missing entry? I am sorry if this is a stupid question......
greetings,
Henning
HenningHAW is offline   Reply With Quote
Old   November 30, 2010, 08:24
T.D. is on a distinguished road
origin (0 0 0);
axis (0 0 1);
omega 18;
greetings,
Henning
can you specify more the type of your Geometry in your flow? and where exactly you apply the rotatingWallVelocity to which patch ?
T.D. is offline   Reply With Quote
Old   December 13, 2010, 16:36
H. Melles
Hello T.D. ,
thank you for your reply and please excuse my late answer!
Meanwhile I found my mistake and in deed it was a stupid one...
I had a mistake in the convertToMeters entry in my blockMeshDict. The boundary layer had a thickness of one meter instead of one Millimeter.
My geometry a rotating plate with a constant flow of oil on its top side.
Old   December 14, 2010, 03:19
OK that's Good
Good Luck
T.D.
interfoam rotatingwall
Getting a concentration field around a bubble in InterFoam azman OpenFOAM Running, Solving & CFD 3 June 7, 2022 04:21
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 06:36
interFoam vs icoFoam on a single-phase case nuovodna OpenFOAM Running, Solving & CFD 1 May 1, 2014 09:37
Slow interFoam compared with other CFD tools? Ralph M OpenFOAM Programming & Development 1 November 17, 2010 06:46
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
