-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Print to a file data at a single point (http://www.cfd-online.com/Forums/openfoam-pre-processing/78281-print-file-data-single-point.html)
ozzythewise July 16, 2010 15:52
Hi all,
What I'm trying to do is get a file printout of information at a point, in this case, I'm looking to printout the stagnation pressure for a simulation that involves flow around a cylinder. I want it in the same format as when it prints out forces and force coefficients, I'm just not sure how to do it. I'm thinking I need to use the probe utility somehow, but I don't know how to use that. If anyone could give me a hand that would pretty really helpful.
Thanks in advance.
ozzythewise July 17, 2010 08:42
Okay, I sort of solved the problem but then added another one. I added the following lines to the end of my controlDict file:
functions
probes
type probes;
functionObjectLibs ("libsampling.so"); //library to load
enabled true;
outputControl timeStep;
outputInterval 1; //how often I want to probe
probeLocations //where I want to probe
(-1 0 0.05)
(0 1 0.05)
(1 0 0.05)
(0 -1 0.05)
(-0.707 0.707 0.05)
(0.707 0.707 0.05)
(0.707 -0.707 0.05)
(-0.707 -0.707 0.05)
(-0.383 0.924 0.05)
(0.383 0.924 0.05)
(0.924 0.383 0.05)
(0.934 -0.383 0.05)
(0.383 -0.924 0.05)
(-0.383 -0.924 0.05)
(-0.924 -0.383 0.05)
(-0.934 0.383 0.05)
fields
p //the field I want to probe
However, when I ran this I got the following error:
--> FOAM Warning :
From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr)
in file lnInclude/dlLibraryTableTemplates.C at line 68
library "libsampling.so" did not introduce any new entries
Which I don't really understand. In addition, the printout was not a .dat file, so when I tried to import the data into excel all the values I got would just be in 1 cell, making data processing pretty difficult.
If anyone has any suggestions for that error, and how I can change the output file format to .dat I would really appreciate it.
Thanks in advance!
-J
