Help Required With Simple Test Case
Old   July 30, 2010, 12:44
Smile Help Required With Simple Test Case
steph79 is on a distinguished road
Hey everyone,
Firstly while I have several years of experience with Fluent I am completely new to OpenFOAM and have had a hard time getting my head around the framework of the program. If someone could help me set up the following case I would be most grateful!
I want to set up a 500m x 25m 2-D structured mesh with 1m^2 cells as a transient, incompressible case (icoFoam ?) with (in Fluent-speak) a velocity inlet, two periodic faces and a pressure outlet. The velocity inlet has been prescribed with a user-defined function in Fluent and I could use some help implementing this in OpenFOAM also.
Later I will introduce some objects in the flow field and go to 3-D etc. but if I could get some help to start up this simple case asap then that would be great.
Thanks!
steph79 is offline   Reply With Quote
Old   July 30, 2010, 12:55
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Your case seems simple to setup in OpenFOAM. The best option to prescribe your user-defined function in the inlet is to use the groovyBC utility that is available in the OpenFOAM wiki.
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   July 30, 2010, 13:43
Thanks for that tip! Off-topic but I'm doing some cleaning right now as my room is a mess so I'll look into this groovyBC facility tomorrow!
I want to specify fluctuating u and v components though, rather than just an oscillating velocity magnitude normal to the inlet boundary.
I've found this test case...
http://openfoamwiki.net/index.php/Bl...Flow_Benchmark
...which is something like what I'll ultimately be doing. What I'll try and do is go as far as I can on my own modifying this code and when I come across problems I'll hopefully have more specific questions. Thanks again!
Old   July 31, 2010, 18:58
Smile
OK, I've managed to set up the case apart from my inlet BC...
Old   August 3, 2010, 07:45
Default groovyBC
http://www.cfd-online.com/Forums/ope...ent-inlet.html
Last edited by steph79; August 4, 2010 at 12:19. Reason: Problem solved on other topic!
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Interfoam Droplet under shear test case adona058 OpenFOAM Running, Solving & CFD 3 May 3, 2010 18:46
Test Case for testing numerical dissipation Flo Main CFD Forum 6 January 25, 2008 12:35
Porous Media test case Alex FLUENT 0 April 9, 2006 08:23
Test Case ganesh Main CFD Forum 0 March 16, 2006 12:34
