rotatingWall with interFoam
I would like to use the rotatingWallVelocity BC with the interFoam solver to simulate a kind of centrifuge. In */0/U I set for my rotatingWall patch type rotatingWallVelocity; origin (0 0 0); axis (0 0 1); omega 18; The solver seems to run without problems but if I watch the results in Paraview, the rotating Wall has no effect to the fluid. But when plotting the velocity of the rotatingWall - patch everything seems to work. The connection between wall and fluid in not working. So, what is my mistake??? Is there a missing entry? I am sorry if this is a stupid question...... greetings, Henning |
can you specify more the type of your Geometry in your flow? and where exactly you apply the rotatingWallVelocity to which patch ? |
Hello T.D. ,
thank you for your reply and please excuse my late answer! Meanwhile I found my mistake and in deed it was a stupid one... I had a mistake in the convertToMeters entry in my blockMeshDict. The boundary layer had a thickness of one meter instead of one Millimeter. My geometry a rotating plate with a constant flow of oil on its top side. |
OK that's Good
Good Luck T.D. |
