November 20, 2010, 13:14 |
rotatingWall with interFoam
H. Melles
I would like to use the rotatingWallVelocity BC with the interFoam solver to simulate a kind of centrifuge. In */0/U I set for my rotatingWall patch type rotatingWallVelocity; origin (0 0 0); axis (0 0 1); omega 18; The solver seems to run without problems but if I watch the results in Paraview, the rotating Wall has no effect to the fluid. But when plotting the velocity of the rotatingWall - patch everything seems to work. The connection between wall and fluid in not working. So, what is my mistake??? Is there a missing entry? I am sorry if this is a stupid question...... greetings, Henning |
November 30, 2010, 09:24 |
#2 | |
Rep Power: 16 |
can you specify more the type of your Geometry in your flow? and where exactly you apply the rotatingWallVelocity to which patch ? |
December 13, 2010, 17:36 |
H. Melles
Hello T.D. ,
thank you for your reply and please excuse my late answer! Meanwhile I found my mistake and in deed it was a stupid one... I had a mistake in the convertToMeters entry in my blockMeshDict. The boundary layer had a thickness of one meter instead of one Millimeter. My geometry a rotating plate with a constant flow of oil on its top side. |
December 14, 2010, 04:19 |
Rep Power: 16 |
OK that's Good
Good Luck T.D. |
interfoam rotatingwall |
Display Modes | |
Getting a concentration field around a bubble in InterFoam | azman | OpenFOAM Running, Solving & CFD | 3 | June 7, 2022 05:21 |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 07:36 |
interFoam vs icoFoam on a single-phase case | nuovodna | OpenFOAM Running, Solving & CFD | 1 | May 1, 2014 10:37 |
Slow interFoam compared with other CFD tools? | Ralph M | OpenFOAM Programming & Development | 1 | November 17, 2010 07:46 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 22:58 |
