Using mapFields if the mesh has different regions
Like Tree2Likes
  • 1 Post By stevenvanharen
Old   February 3, 2011, 06:31
Default Using mapFields if the mesh has different regions
Steven van Haren
stevenvanharen is on a distinguished road
Dear all,
I would like to use mapFields to map the velocity field form a simulation containing only one region to a simulation containing multiple regions. Is this possible? Does somebody know how to do it?
On of the regions in the targer folder is the same size as the region in the source folder.
Any help will be appreciated.
Kind regards,
Steven
stevenvanharen is offline   Reply With Quote
Old   February 3, 2011, 13:12
Steven van Haren
Fixed it myself, turned out it was not to hard
If anyone needs it let me know.
Old   March 3, 2011, 01:16
Lauri Rintala
laurint is on a distinguished road
I would like to hear your solution. I'm mapping from mesh with two region onto a mesh with similar regions, but nothing seems to work.
Lauri
laurint is offline   Reply With Quote
Old   March 3, 2011, 04:03
Steven van Haren
Just take a look at this source code.
I added the -region option to the utility and changed:
  fvMesh meshTarget
            IOobject
                fvMesh::defaultRegion,
                runTimeTarget.timeName(),
                runTimeTarget
into:
  fvMesh meshTarget
            IOobject
                            regionName,
                            runTimeTarget,
                            Foam::IOobject::MUST_READ
                runTimeSource.timeName(),
                runTimeSource*/
However, this will only work for consistent meshes and serial cases.
samiam1000 likes this.
Old   March 3, 2011, 04:53
Lauri Rintala
Thank you for the quick reply. Your solution works perfectly.
I added the region-thing also for the source, although now they have to have same names.
Old   October 29, 2013, 02:37
Samuele Z
samiam1000 is on a distinguished road
I know it's an old post, but I am having the same problems. I would like to map fields from a multiregion problem to the same multiregion one (I mean, same mesh and same regions' name and so on).
I tried to compile the archive you shared, but I get this error:
zampini@pc-zampini:~/OpenFOAM/zampini-2.2.0/applications/utilities/preProcessing/mapRegionFields$ wmake
SOURCE=mapLagrangian.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude -I/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -IlnInclude -I. -I/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mapLagrangian.o
In file included from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/Field.H:360:0,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/scalarField.H:38,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/dimensionSet.H:46,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/dimensionedType.H:40,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/dimensionedScalar.H:38,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/dimensionedTypes.H:31,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/GeometricField.H:43,
                 from MapLagrangianFields.H:37,
                 from mapLagrangian.C:26:
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/Field.C: In member function ‘void Foam::Field<Type>::operator=(const Foam::VectorSpace<Form, Cmpt, nCmpt>&)’:
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/Field.C:680:42: warning: typedef ‘VSType’ locally defined but not used [-Wunused-local-typedefs]
     typedef VectorSpace<Form,Cmpt,nCmpt> VSType;
mapLagrangian.C: In function ‘void Foam::mapLagrangian(const Foam::meshToMesh&)’:
mapLagrangian.C:173:29: error: no matching function for call to ‘Foam::passiveParticle::passiveParticle(Foam::Cloud<Foam::passiveParticle>&, const Foam::Vector<double>&, const int&)’
mapLagrangian.C:173:29: note: candidates are:
In file included from mapLagrangian.C:28:0:
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/passiveParticle.H:98:9: note: Foam::passiveParticle::passiveParticle(const Foam::passiveParticle&)
         passiveParticle(const passiveParticle& p)
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/passiveParticle.H:98:9: note:   candidate expects 1 argument, 3 provided
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/passiveParticle.H:87:9: note: Foam::passiveParticle::passiveParticle(const Foam::polyMesh&, Foam::Istream&, bool)
         passiveParticle
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/passiveParticle.H:87:9: note:   no known conversion for argument 1 from ‘Foam::Cloud<Foam::passiveParticle>’ to ‘const Foam::polyMesh&’
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/passiveParticle.H:75:9: note: Foam::passiveParticle::passiveParticle(const Foam::polyMesh&, const vector&, Foam::label, bool)
         passiveParticle
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/passiveParticle.H:75:9: note:   no known conversion for argument 1 from ‘Foam::Cloud<Foam::passiveParticle>’ to ‘const Foam::polyMesh&’
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/passiveParticle.H:61:9: note: Foam::passiveParticle::passiveParticle(const Foam::polyMesh&, const vector&, Foam::label, Foam::label, Foam::label)
         passiveParticle
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/passiveParticle.H:61:9: note:   candidate expects 5 arguments, 3 provided
mapLagrangian.C:210:60: error: no matching function for call to ‘Foam::meshSearch::meshSearch(const Foam::fvMesh&, bool)’
                 meshSearch targetSearcher(meshTarget, false);
mapLagrangian.C:210:60: note: candidates are:
In file included from mapLagrangian.C:29:0:
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude/meshSearch.H:180:9: note: Foam::meshSearch::meshSearch(const Foam::polyMesh&, const Foam::treeBoundBox&, Foam::polyMesh::cellRepresentation)
         meshSearch
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude/meshSearch.H:180:9: note:   no known conversion for argument 2 from ‘bool’ to ‘const Foam::treeBoundBox&’
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude/meshSearch.H:171:9: note: Foam::meshSearch::meshSearch(const Foam::polyMesh&, Foam::polyMesh::cellRepresentation)
         meshSearch
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude/meshSearch.H:171:9: note:   no known conversion for argument 2 from ‘bool’ to ‘Foam::polyMesh::cellRepresentation’
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude/meshSearch.H:149:9: note: Foam::meshSearch::meshSearch(const Foam::meshSearch&)
         meshSearch(const meshSearch&);
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude/meshSearch.H:149:9: note:   candidate expects 1 argument, 2 provided
mapLagrangian.C:242:58: error: no matching function for call to ‘Foam::IOPosition<Foam::passiveParticle>::IOPosition(Foam::Cloud<Foam::passiveParticle>&)’
                 IOPosition<passiveParticle>(targetParcels).write();
mapLagrangian.C:242:58: note: candidates are:
In file included from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/IOPosition.H:96:0,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/CloudIO.C:28,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/Cloud.C:467,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/Cloud.H:342,
                 from mapLagrangian.C:27:
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/IOPosition.C:31:1: note: Foam::IOPosition<ParticleType>::IOPosition(const CloudType&) [with CloudType = Foam::passiveParticle]
 Foam::IOPosition<CloudType>::IOPosition(const CloudType& c)
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/IOPosition.C:31:1: note:   no known conversion for argument 1 from ‘Foam::Cloud<Foam::passiveParticle>’ to ‘const Foam::passiveParticle&’
In file included from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/CloudIO.C:28:0,
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/IOPosition.H:50:7: note: Foam::IOPosition<Foam::passiveParticle>::IOPosition(const Foam::IOPosition<Foam::passiveParticle>&)
 class IOPosition
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/IOPosition.H:50:7: note:   no known conversion for argument 1 from ‘Foam::Cloud<Foam::passiveParticle>’ to ‘const Foam::IOPosition<Foam::passiveParticle>&’
In file included from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/particle.H:562:0,
                 from /home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/passiveParticle.H:38,
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/particleTemplates.C: In instantiation of ‘Foam::scalar Foam::particle::trackToFace(const vector&, TrackData&) [with TrackData = double; Foam::scalar = double; Foam::vector = Foam::Vector<double>]’:
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/particleTemplates.C:193:54:   required from ‘Foam::label Foam::particle::track(const vector&, TrackData&) [with TrackData = double; Foam::label = int; Foam::vector = Foam::Vector<double>]’
mapLagrangian.C:178:77:   required from here
/home/zampini/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude/particleTemplates.C:207:43: error: ‘double’ is not a class, struct, or union type
     typedef typename TrackData::cloudType cloudType;
make: *** [Make/linux64GccDPOpt/mapLagrangian.o] Error 1
I am using OpenFOAM 2.2.1.
Any idea?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   November 5, 2013, 17:31
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Did you compiled this utility after modification.
Ahmed Khattab is offline   Reply With Quote
Old   November 7, 2013, 18:39
Steven van Haren
I think the 2.2.2 release has the options sourceRegion and targetRegion as standard in the utility mapFields, so no need to do anything yourself!
Old   November 8, 2013, 03:00
Samuele Z
That is what I did, finally.
Thanks a lot,
Samuele
Issues with mapFields BlackBoatNavArch OpenFOAM Pre-Processing 38 May 28, 2021 16:29
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
Solution technique/ Mesh type/ Cell limit/ Multi-zone regions in FLUENT zandi FLUENT 0 April 6, 2009 04:04
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
