September 17, 2014, 20:19 |
checking MeshSize and first cell position
Hi there
After several unsuccessful research, I am actually searching of a way to check my mesh size specially the near wall. Like having the minimum mesh size on x direction y , z... the average size and the maximum size, in order to check my first cell position over the wall. and is there a trick to use several time rifineWallLayer utility for example refineWallLayer bottom 0.5 -times 5 (=> and then it does it 5 times) Thanks Gregoire Junqua |
October 29, 2014, 08:40 |
Joachim Herb
Rep Power: 21 |
You probably have to program this yourself: Have a look at the source code of the checkMesh and yPlus tools.
