-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Differences zeroGradient // inletOutlet (http://www.cfd-online.com/Forums/openfoam-pre-processing/89121-differences-zerogradient-inletoutlet.html)
Tobi June 5, 2011 14:02
Hey all,...
just one question. What 's the difference between, zeroGradient and inletOutlet//outletInlet???
And if you get a flow through the patch "inletOutlet/outletInlet" does it switch between zeroGradient and fixedValue?
Greetings Tobi
norman1981 June 6, 2011 02:42
Hi Tobias,
to the best of my knowledge inletOutlet BC type works in this way:
- if the flow is going out the domain it behaves as a zeroGradient BC
- if the flow is coming inside the domain it behaves as a fixedValue BC
Hope it helps
Regards
Norman
Tobi June 6, 2011 03:55
Hey thanks.
Just one question left.
If it switches to fixedValue. Are there every faces declared to fixedValue?
And is that a static switch? Or a dynamic switch between zeroGradient and fixedValue?
Thanks in advance
Tobi
