November 19, 2011, 07:28 |
decomposePartdict in OpenFOAM 2.0
Jozsef Rideg
I have the following message: --> FOAM FATAL IO ERROR: Expected a ')' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 24 the label 2 file: /home/xy/OpenFOAM/xy-2.0.x/run/26LES_2D_Gauss_linearUpwind_leastSquares__GAMG_GAM G/system/decomposeParDict::simpleCoeffs::n at line 24. From function Istream::readEnd(const char*) in file db/IOstreams/IOstreams/Istream.C at line 111. FOAM exiting I do not understand, what is the problem. I used the same file for dividing into 4 domains, without any problem. Maybe it's trivial, but I do not see the syntax error. Any idea? Thanks in advance! Regards, TKE /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 8; method simple; simpleCoeffs { n ( 2 2 2 2 2 2 2 1 ); delta 0.001; } hierarchicalCoeffs { n ( 1 1 1 ); delta 0.001; order xyz; } manualCoeffs { dataFile ""; } distributed no; roots ( ); // ************************************************** *********************** // |
November 19, 2011, 09:16 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings TKE,
Soooo you want to solve the case in 8 dimensions!? You're meant to specify the number of divisions over each dimension, not the number of divisions per parallel process And please use the Code tag for pasting code (the button with "#" on it in advanced edit mode). Quote:
Bruno
November 20, 2011, 07:35 |
Thanks
Jozsef Rideg
Thanks for your answer!
Maybe the state of physics today is not ready yet for my 8-dimensional calculations... Regards, TKE |
Updating OpenFOAm 1.6 to 2.0 | fs82 | OpenFOAM | 1 | May 3, 2012 09:19 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Building a custom solver on OpenFOAM 2.0 | wschosta | OpenFOAM Programming & Development | 1 | July 8, 2011 15:07 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
