vaporize water - boundary conditions
Hi together,
i am working on a testcase in which water vaporizes on a heated wire (diameter = 0,1 mm) The case is working well but i 've problems with my BC couse my steam don't get out of my integration area. In the video i added you can see that its circulating in the case but i wanna let it out. VIDEO : http://ww3.cad.de/foren/ubb/uploads/...eWater.mpg.zip So my Boundary-File looks like that: Code:
my U and p_rgh files are: Code:
dimensions [ 0 1 -1 0 0 ];internalField uniform ( 0 0 0 ); and the p_rgh file is: Code:
dimensions [ 1 -1 -2 0 0 ];internalField uniform 101325; Any tricks or suggestions? Thx in advance, Tobi |
hi
first of All, what is your solver? second i may try inletOutlet or zeroGradient for bottom in U |
Hey nimasam, my Solver is interPhaseChangeFoam with implement temperatur field and temperatur depended pSat. Okay i ll try inletOutlet/zeroGradient for the bottom. I 've tryed to use pressureInletOutletVelocity for the top BC like in the tutorial "breakdam" but the steam can not get out. okay i ll change the bottom BC and ll tell you if its working. Thx for replaying Tobi |
i 've solved the case with your advice to change the bottom to zeroGradient or inletOutlet (refer to U). The steam doesn#t get out of the boundarys :( |
Hi Tobi,
Do you have a reference for the temperature dependent Psat model that you are using? Thanks, Eric |
Hi Eric, yes i have the temperature dependent Psat correlation from August-Roche-Magnus. My simulation is working now and the solution seeems very good. But i am waiting for experimental values. I am still trying to get a good solution and handle the BC for that case. Hope i could help you. Tobi |
Hi Tobi,
Thanks. Can you give me a citation for August-Roche-Magnus? There is a student in our group who is looking at laser-induced vaporization for creating a bubble. Very high-temperature, short duration pulse of energy. She has the heat-transfer and energy absorption modeled, and is now working on the vaporization. Eric Quote:
Hi Eric, i used the equation from http://www.tfd.chalmers.se I ve no citation for that - exept google and wiki :) and you can implement it with that code: Code:
{ PS: I am interested to get the bubbles involved in my solver couse i wanna simulate the heat transfer from a heated wire. Like - free convection bubble convection and film convection i am not sure if thats correct translated but in my case i don 't get bubbles. |
