Pressure driven flow
Old   December 4, 2011, 04:22
Default Pressure driven flow
ChrisPro is on a distinguished road
Hey!
I'm trying to simulate the flow through a block knowing only the pressure at the inlet. The velocity at the inlet is calculated with "pressureInletVelocity".
But what adjustments do I have to set at the outlet?
Are these correct:
outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           $internalField;
or is there something similar to "pressureInletVelocity" but for the Outlet?
regards
Christian
ChrisPro is offline   Reply With Quote
BCs for pressure driven flow using rhoCentralFoam eric.m.tridas OpenFOAM 7 January 10, 2015 09:31
Reversed flow at pressure outlet Seeker Phil FLUENT 9 January 2, 2010 05:21
pressure BC in buoynacy driven flow Sasha FLUENT 3 October 11, 2006 10:08
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
