-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Command Help (http://www.cfd-online.com/Forums/openfoam-pre-processing/95227-command-help.html)
shridhargrao December 10, 2011 05:17
Command Help
What does this command actually do "grep"Net mass flux" $1 |awk '{print $3}' > timeList.dat" ?
wyldckat December 12, 2011 18:09
Greetings Shridhar,
A bit of context would be nice... anyway, that command line is split in two parts:
  1. grep searches for the lines that have "Net mass flux".
  2. The output from grep gets piped through "|" and sent to awk for processing; awk prints out the 3rd value it picks up on each of those lines, if I'm not mistaken.
To learn more about grep and awk:
man grep
man awk
Searching online for tutorials for each command will also get you more information. I also suggest tutorials about bash, so you can understand the first "$1" ;)
Best regards,
Bruno
