How can I get rid of defaultFaces in o folder?
Old   February 7, 2013, 14:03
Default How can I get rid of defaultFaces in o folder?
Abbas Rahimi
AbbasRahimi is on a distinguished road
Hello folks,
I'm very new to OpenFOAM and I'm trying to run a case of laminar flow around a cylinder locate in round boundaries. When I made this mesh in Salome I had to partition geometry to have flow coming from one side of circle and leaving from other side. However some internal faces has been created which when I import this file in openFOAM and trying to run it, I face to error that I have to assign type of boundary for default faces which there are not boundaries. I wonder if anyone can give me some hints.
Thank you
AbbasRahimi is offline   Reply With Quote
retreat internalface
Writing IOdictionary to user-defined folder Arnoldinho OpenFOAM Programming & Development 3 June 16, 2021 04:04
How to get rid of the defaultFaces, Courant number diverge. liguifan OpenFOAM Running, Solving & CFD 1 April 30, 2011 23:13
[Gmsh] How to get rid of the defaultFaces liguifan OpenFOAM Meshing & Mesh Conversion 0 April 30, 2011 22:53
Can I modify runTimeWrite() to output results into one folder? ovie OpenFOAM 12 January 22, 2011 19:52
[snappyHexMesh] Folder structure from snappyHexMesh elisenda OpenFOAM Meshing & Mesh Conversion 3 January 6, 2010 03:52
