wall function for twoPhaseEulerFoam
Like Tree2Likes
  • 1 Post By alberto
  • 1 Post By alberto
Old   January 10, 2012, 08:20
Default wall function for twoPhaseEulerFoam
Ofc
Ofc is on a distinguished road
Hello Foamers,
as the title says I look for some good wall function using the twoPhaseEulerFoam solver. Right now I deal with y+ values around 0.001 to 10. I tried zeroGradient for k and epsilon, but I was not sure about the results. I tried to get higher values of y+ (above 30) for some walls and use the kqrWallFunction, but when I try to run the solver it says this wall function does not exist. Anyone knows how to add the function to the solver?
Also, since I have a small slit with very low y+ values I thought of using a laminar case there. Is there a option in OpenFOAM to use two different solvers (1 laminar 1 turbulent) for the areas or do I have to run the case turbulent first then export the values at the slit inlet and outlet and rerun the slit in another case?
Thanks for your time & help,
Ofc is offline   Reply With Quote
Old   January 11, 2012, 09:01
Alberto Passalacqua
Originally Posted by Ofc View Post
Hello Foamers,
The twoPhaseEulerFoam solver uses the same wall-functions implemented in bubbleFoam (the code is linked, that's why you do not see it into the twoPhaseEulerFoam directory. The tutorials using the turbulence model rely on wall-functions too.
Best,
Ofc likes this.
Alberto Passalacqua
Old   January 12, 2012, 09:30
Ofc
Thanks Alberto,
I did look up the bubbleFOAM files now. For it seems that the solver always takes a wall function
"if (isA<wallFvPatch>(currPatch))" (from the wallFunctions.H)
I translated this line with "if a boundary is defined as a wall in the file constant/polyMesh/boundary
What is the difference if I change the wall function in the /0 folder?
Old   January 12, 2012, 11:01
Alberto Passalacqua
Thanks Alberto,
Yes, if you use the k-epsilon model in twoPhaseEulerFoam, you are always using the hard-coded wall-function in the code. If you specify a wall-function in the 0/ directory, it will be overridden by the solver, and it won't have any effect.
Best,
Ofc likes this.
Alberto Passalacqua
Wall function for velocity? johnblund OpenFOAM 3 September 6, 2022 07:22
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Need some wall function approaches! yka8150 Main CFD Forum 0 September 21, 2009 23:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
