February 10, 2012, 16:55 |
error in blockMesh with edged Duct explicit
Dear Foamer,
i was trying to run one of tutorials cases. it was "angledDuctExplicit" case. when t tried to run the command blockMesh i got this error. Create time Creating block mesh from "/home/khattab/ahmed-2.1.0/run/tutorials/incompressible/porousSimpleFoam/angledDuctExplicit/constant/polyMesh/blockMeshDict" --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'dnl>' on line 20 and ending at line 23" file: /home/khattab/ahmed-2.1.0/run/tutorials/incompressible/porousSimpleFoam/angledDuctExplicit/constant/polyMesh/blockMeshDict at line 23. From function primitiveEntry::readEntry(const dictionary&, Istream&) in file lnInclude/IOerror.C at line 132. FOAM exiting pleas help, regards, |
May 15, 2012, 11:16 |
#2 | |
FDA
I'm trying to run this template and I faced the same problem. Someone has suggestions? Thanks! |
May 15, 2012, 11:41 |
Martin
Rep Power: 21 |
you should call Code:
m4 constant/polyMesh/blockMeshDict.m4 > constant/polyMesh/blockMeshDict Martin |
Display Modes | |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
Fabric Duct Modeling | Dan | FLUENT | 0 | June 30, 2008 16:00 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 12:59 |
modelling fuel cell duct in fluent | rajesh kumar tippabhotla | FLUENT | 2 | October 7, 2004 13:04 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 18:49 |
