-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Multiple cell zones definition (http://www.cfd-online.com/Forums/openfoam-pre-processing/97826-multiple-cell-zones-definition.html)
ciberbob1987 February 26, 2012 15:36
Hi everybody,
I'm using porousSimpleFoam and I need to define multiple porous zones.
The computational domain is composed by 6 porous petals (similar to 6 pipes), each one twisted with other around a central hole (see attached image).
http://vici.oceanprosystem.com/marco/IMM_01_domain.png
At the moment, the porous region (isotropic) is defined by the setSet command and the batch file:
cellSet porousCylinder new surfaceToCell "porousCylinderInlets.stl" ( (0 0 0) (-0.017 0 0) ) true true false -1 -100
a render of porousCylinderInlets.stl is shown in the image below:
http://vici.oceanprosystem.com/marco...nderInlets.png
I need to define an anisotropic porosity along the axial and radial directions of each petal.
I think that the right way is:
  1. define various sections for each petal, of fixed thickness along the z axe (an example is given in the image)
    http://vici.oceanprosystem.com/marco/petal_part.png
  2. group in a set the cells of every section
  3. create a cellZones from the sets
  4. define a local axes and porosity for each zone in porousZones file
I can generate sections (only surface!) with the script attached. A render of the sections extracted is shown below:
http://vici.oceanprosystem.com/marco/petal_sections.png
Now, I want to ask if is it possible to generate the cellSets and CellZones (points 1, 2, 3 of above list) by a script.
Many thanks to all.
Marco
ciberbob1987 February 26, 2012 15:49
1 Attachment(s)
I forgot the script to generate the section surfaces :D
