Home > Forums > OpenFOAM Pre-Processing
pyFoam DecomposePar arbitrary Timestep
Like Tree1Likes
  • 1 Post By gschaider
Old   March 12, 2012, 05:02
Default pyFoam DecomposePar arbitrary Timestep
Benjamin
elys is on a distinguished road
Dear forum,
I was looking into pyFoam and like it a lot. However, I have difficulties with pyFoamDecompose.py if I want to decompose a case at a certain timestep and not the last one. I couldnt find an option to do so within the wiki or --help. Does anybody has a suggestion to solve this problem? And a second question: Beside that parallel runs are automatically reconstructed, is there also a script to do so in pyFoam (with certain time steps)??
Thanks in advance,
Ben
elys is offline   Reply With Quote
Old   March 12, 2012, 19:47
Assistant Moderator
Bernhard Gschaider
Originally Posted by elys View Post
Dear forum,
Thanks in advance,
Ben
Selecting the timestep is currently not supported by this utility (but can be if a feature request shows up on the openfoam-extend-Mantis). As a workaround you can use it with the --no-decompose-option to just generate decomposeParDict and then call decomposePar with the appropriate time-options
elys likes this.
Old   March 13, 2012, 03:27
Benjamin
Thanks Bernhard for the explanation! The workaround will do.
Best,
Ben
Old   March 13, 2012, 10:10
Default Decomposing GGI case
Stefan
SD@TUB is on a distinguished road
Sorry, that i chime in with my problem of decomposing a case for GGI with, e.g.
pyFoamDecompose.py --globalFaceZones='( insideZone outsideZone )' . 4
followed with error:
Traceback (most recent call last):
File "/usr/local/bin/pyFoamDecompose.py", line 5, in <module>
Decomposer()
File "/usr/local/lib/python2.6/dist-packages/PyFoam/Applications/Decomposer.py", line 40, in __init__
nr=2)
File "/usr/local/lib/python2.6/dist-packages/PyFoam/Applications/PyFoamApplication.py", line 155, in __init__
result=self.run()
File "/usr/local/lib/python2.6/dist-packages/PyFoam/Applications/Decomposer.py", line 162, in run
fZones=eval(self.opts.globalFaceZones)
File "<string>", line 1
SyntaxError: invalid syntax
What is the problem? Help message stats:
--globalFaceZones=GLOBALFACEZONES
Global face zones. A python string. Used for the GGI interface. Ex: '(GGI_Z1 GGI_Z2)'
I tried different expressions. I am using pyFoam 0.5.6 on Debian Squeeze with Python 2.6.6.
Thank you very much in advance!
/Stefan
SD@TUB is offline   Reply With Quote
Old   March 13, 2012, 19:20
Assistant Moderator
Bernhard Gschaider
/Stefan
I think the description is inconsistent with what is actually needed. Try
'["GGI_Z1","GG1_Z2"]'
Old   March 14, 2012, 04:37
Stefan
Thanks a bunch! It is working.
/Stefan
Old   March 14, 2012, 06:07
Assistant Moderator
Bernhard Gschaider
/Stefan
OK. I'll adapt the help-message accordingly (for this time without a bug-report )
Thread Tools
Trackbacks are On
Restart 2-way FSI with different timestep? Lance CFX 11 April 17, 2013 00:37
decomposePar gives errors of_user_ OpenFOAM 1 July 4, 2011 05:27
pyFoam, pyFlu, extend: How does they relate? Horus OpenFOAM 9 May 21, 2011 12:49
How to interrupt unsteady calculation and carry on without timestep increase? aleisia FLUENT 1 March 19, 2011 00:02
pyFoam batch set up for OF 1.7 eelcovv OpenFOAM Running, Solving & CFD 3 January 19, 2011 09:38
