Home > Forums > OpenFOAM Pre-Processing
defining variables in funkySetFieldDict
Old   April 5, 2012, 17:33
Default defining variables in funkySetFieldDict
Victoria Suponitsky
supvika is on a distinguished road
I would like to define some variables and use them in the evaluation of 'expression' in 'funkySetFieldsDict'. I added it according to the example in www.openfoamworkshop.org/6th...2011/.../gschaider_slides.pdf as:
setCircle
field alpha1 ;
keepPatches true ;
expression "width" ;
variables (
"width=max(pos().x)-min(pos().x);"
When I run funkySetFields the following error message always happens:
Create time
Create mesh for time = 0
Time = 0
Using funkySetFieldsDict
Part: setCircle
Putting "width" into field alpha1 at t = "0" if condition "true" is true
Keeping patches unaltered
--> FOAM FATAL ERROR:
Parser Error at "1.0-4" :"field width not existing or of wrong type"
"width"
From function parsingValue
in file ValueExpressionDriver.C at line 84.
FOAM exiting
I will be very gratefull if somebody can help me to resolve this issue. Just to make sure, without attempting to define the variables funkySetFiles works fine. I am using OF1.7.
Thanks,
Victoria
supvika is offline   Reply With Quote
Old   April 6, 2012, 07:08
Eelco van Vliet
eelcovv is on a distinguished road
I wonder if your definition for width does not give 0 as a outcome, since you take the max of the local x-position (which is equal to the local x-position) and subtract the min of the local x-position (which is again equal to the local x-position).
Apart from that, it complains about the type of the field, perhaps that the type definition in your alpha1 field is not set to volScalarField.
For the rest I don't see anything wrong in your syntax, so it should work.
eelcovv is offline   Reply With Quote
Old   April 9, 2012, 18:11
Assistant Moderator
Bernhard Gschaider
setCircle
field alpha1 ;
keepPatches true ;
variables (
Create time
Time = 0
Part: setCircle
"width"
FOAM exiting
Just tried your expression and it works fine for me. Which version of FSF are you using? Only the ones that come with swak4Foam (not the standalone) support variables
Old   April 9, 2012, 23:43
Victoria Suponitsky
Hello Bernhard,
Thanks a lot for your response. I indeed used the stand alone FSF version.
Now with swak4Foam everything works.
Thanks again,
Victoria
Thread Tools
Trackbacks are On
ADDITIONAL VARIABLES LIMITERS N.P CFX 5 December 1, 2011 08:47
Defining additionally variables of U in OF 1.6 lentschi OpenFOAM 3 March 7, 2011 10:10
Accessing other variables in defining boundary condition Cynthia Poon OpenFOAM Running, Solving & CFD 0 March 25, 2009 04:36
Defining New Variables Tim Phoenics 0 September 30, 2003 14:52
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
