killed "snappyHexMesh"
hi all
I'v run the snappyHexMesh and got the problem, Killed.. Anyone can help me, please ? thanks// hs ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ $ snappyHexMesh // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 3.84 s Overall mesh bounding box : (-25 -6 -0.7) (5 6 0.4) Relative tolerance : 1e-06 Absolute matching distance : 3.23297e-05 Reading refinement surfaces. Read refinement surfaces in = 0.05 s Reading refinement shells. Refinement level 1 for all cells inside box1 Refinement level 2 for all cells inside box2 Refinement level 2 for all cells inside box3 Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0 s Reading features. Read features in = 0 s Determining initial surface intersections ----------------------------------------- Edge intersection testing: Number of edges : 1228620 Number of edges to retest : 1228620 Number of intersected edges : 11643 Calculated surface intersections in = 4.15 s Initial mesh : cells:396000 faces:1228620 points:437052 Cells per refinement level: 0 396000 Adding patches for surface regions ---------------------------------- Patch Type Region ----- ---- ------ hull: 4 wall hull_CreatedbyGmsh Added patches in = 0.07 s Selecting decompositionMethod simple Refinement phase ---------------- Found point (-2 0 0) in cell 269929 on processor 0 Surface refinement iteration 0 ------------------------------ Marked for refinement due to surface intersection : 15305 cells. Determined cells to refine in = 1.35 s Selected for refinement : 15305 cells (out of 396000) Edge intersection testing: Number of edges : 1585770 Number of edges to retest : 459084 Number of intersected edges : 46521 Refined mesh in = 4.77 s After refinement surface refinement iteration 0 : cells:503135 faces:1585770 points:580318 Cells per refinement level: 0 380695 1 122440 Surface refinement iteration 1 ------------------------------ Marked for refinement due to surface intersection : 62292 cells. Determined cells to refine in = 0.12 s Selected for refinement : 67930 cells (out of 503135) Edge intersection testing: Number of edges : 3154578 Number of edges to retest : 2023445 Number of intersected edges : 185977 Refined mesh in = 11.89 s After refinement surface refinement iteration 1 : cells:978645 faces:3154578 points:1198876 Cells per refinement level: 0 374987 1 105882 2 497776 Surface refinement iteration 2 ------------------------------ Marked for refinement due to surface intersection : 327 cells. Determined cells to refine in = 0.31 s Selected for refinement : 379 cells (out of 978645) Edge intersection testing: Number of edges : 3163407 Number of edges to retest : 28843 Number of intersected edges : 186257 Refined mesh in = 8.79 s After refinement surface refinement iteration 2 : cells:981298 faces:3163407 points:1202428 Cells per refinement level: 0 374935 1 105971 2 500392 Surface refinement iteration 3 ------------------------------ Marked for refinement due to surface intersection : 13 cells. Determined cells to refine in = 0.3 s Selected for refinement : 15 cells (out of 981298) Edge intersection testing: Number of edges : 3163755 Number of edges to retest : 1287 Number of intersected edges : 186262 Refined mesh in = 8.44 s After refinement surface refinement iteration 3 : cells:981403 faces:3163755 points:1202566 Cells per refinement level: 0 374933 1 105974 2 500496 Surface refinement iteration 4 ------------------------------ Marked for refinement due to surface intersection : 1 cells. Determined cells to refine in = 0.31 s Selected for refinement : 2 cells (out of 981403) Edge intersection testing: Number of edges : 3163803 Number of edges to retest : 167 Number of intersected edges : 186262 Refined mesh in = 8.32 s After refinement surface refinement iteration 4 : cells:981417 faces:3163803 points:1202586 Cells per refinement level: 0 374932 1 105981 2 500504 Surface refinement iteration 5 ------------------------------ Marked for refinement due to surface intersection : 0 cells. Determined cells to refine in = 0.25 s Selected for refinement : 0 cells (out of 981417) Stopping refining since too few cells selected. Removing mesh beyond surface intersections ------------------------------------------ Found point (-2 0 0) in cell 562633 in global region 0 out of 1 regions. Keeping all cells in region 0 containing point (-2 0 0) Selected for keeping : 981417 cells. Edge intersection testing: Number of edges : 3163803 Number of edges to retest : 0 Number of intersected edges : 186262 Shell refinement iteration 0 ---------------------------- Marked for refinement due to refinement shells : 304456 cells. Determined cells to refine in = 10.17 s Selected for internal refinement : 327315 cells (out of 981417) Killed ~~~~~~~~~~~~~~~~~~~~~ |
Probably you have "ulimit" set to a smaller value for the process memory than what snappyHexMesh would want to use for your case. If that happens, the system will kill the snappyHexMesh process.
thank you for your reply.
hs// |
