-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   nuTilda dict? (http://www.cfd-online.com/Forums/openfoam-pre-processing/99686-nutilda-dict.html)
mmcs21 April 9, 2012 18:58
nuTilda dict?
hi
would anyone be able to provide me with the default nuTilda dict for the 0 time directory please?
I'm hoping to run spallart sim, unfortunately i deleted all the default tutorials that would've contained this info! (i needed space on linux partition)
thanks!
lovecraft22 April 10, 2012 04:41
You could still download the whole openfoam package and you'll have everything back again:
http://www.openfoam.org/download/source.php
mmcs21 April 10, 2012 09:52
thank you but i was hoping to avoid this. I've still very limited space left on my linux partition.
I've never set up a spallart problem so the spallart-allmaras case is all i need.....
if anyone had this, that'd be great
thanks
lovecraft22 April 10, 2012 12:22
If you tell me what's the tutorial you need exactly I'll upload that for you!
mmcs21 April 10, 2012 14:51
that would be excellent thank you!
i believe it is the incompressible/simplefoam/airFoil2D tutorial
thanks
matt
lovecraft22 April 10, 2012 14:55
1 Attachment(s)
Here you go!
(Had to get rid of the polyMesh folder because the file exceeded the maximum upload dimension, hope that's ok for you!)
mmcs21 April 10, 2012 15:20
thanks!
very useful
akshaybagi April 26, 2013 03:22
nu and nuTilda
Can anyone please tell me what do nu and nuTilda files signify in OpenFOAM?
bscphil April 26, 2013 04:54
  • "nu" stands for the kinematic viscosity in [m^2/s] with "nu= mu/rho" ("mu" = dynamic viscosity [Pa*s], "rho" = density [kg/m^3] )
  • "nut" is the turbulent viscosity (incompressible) and "mut" the turbulent viscosity (compressible)
  • "nuTilda" is a field variable only (?) for the "Spalart Allmaras turbulence model" --> look at the source code (OpenFOAM/src/turbulenceModels/incompressibe/RAS/SpalartAllmaras/SpalartAllmaras.C) or http://courses.washington.edu/mengr5...our-report.pdf ( Equation (18) )
Is this what you are looking for ???
akshaybagi April 27, 2013 03:37
ya got it thanks:)
Esther Jin August 5, 2016 04:22
Does it mean if I don't use "Spalart Allmaras turbulence model", it's not necessary to have nuTilda Dict in 0 folder?
Does nuSgs Dict needed for LES simulation?
Thank you!
