How to implement equation of mixture fraction and variance of mixture fraction?
Like Tree2Likes
  • 2 Post By niklas
Old   April 23, 2012, 04:13
Default How to implement equation of mixture fraction and variance of mixture fraction?
Tobi's Avatar
Tobias Holzmann
I am using OF for two years now and wanna get deeper into the code and wanna make a new solver using an old one and transform the steady equations into the time dependent equations.
Okay my problem for now is, that I am not sure if I interpret the *Eqn.H files correct. I read a few threats here in the forum which helped me a lot but now I need your help.
I added an attachment with my problem. There you can see my solving equations. I just wanna have a look at the differential equations but I think that I transformed them not right, or?
Further more I do not know what "Sp" means.
Thx in advance.
Regards Tobi
Old   April 23, 2012, 08:17
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
fvm::Sp denotes an implicit source term. You can ignore it when translating code into equations, it's purely related to numerics.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   April 23, 2012, 09:32
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
suppose you want to solve this equation
dU/dt = A + BU
implemented like
fvm:ddt(U) == A + B*U
using euler scheme,
this results in
U^n - U^{n-1} = dt*A + dt*B*U^{n-1}
U^n = dt*A + (dt*B + 1)*U_{n-1}
implemented like this
fvm::ddt(U) == A + fvm::Sp(B, U)
this results in
U^n - U^{n-1} = dt*A + dt*B*U^n
(1 - dt*B)*U^n = dt*A + U^{n-1}
so the first implementation is explicit treatment of the B*U term, while the other is implicit treatment.
Hope this makes it clearer
This also makes it possible to do some 'cheating' of large explicit source-terms by linearizing them
again...
dU/dt = A + B*U = A*1 + B*U + A*(U/U) + B*U
which can be implemented like
fvm::ddt(U) = fvm:Sp(A/U, U) + B*U
which in turn is treated numerically like
U^{n} - U ^{n-1} = dt*(A*U^n / U^{n-1} + B*U^{n-1})
so you see now that A is no longer multiplied by 1, but by something else, which for the
converged solution hopefully is 1 and have a stabilizing effect on the solver.
sylvester and Tobi like this.
niklas is offline   Reply With Quote
Old   April 24, 2012, 04:24
Tobi's Avatar
Tobias Holzmann
Hi nicklas,
thanks for your good explanation!
I used your statement and generated a file (attachment). can you have a look at the file?
I am interessted in the last line I added. Thats my understanding of your post.
The second file is a transformation from openfoam equation code into scalar equation. Is that correct? Its a while ago that I used grad, div and laplacian.
thx in advance
tobi
Old   December 1, 2015, 13:23
Tobi's Avatar
Tobias Holzmann
I just want to comment, that the "Schemes.pdf" file is incorrect.
Keep foaming,
Tobias Holzmann
Old   December 18, 2019, 23:55
Post fvc and Sp
Deepak J
dj18deepak is on a distinguished road
Sorry for bumping into this old thread. I am a beginner in CFD and OpenFoam and i am trying to implement mixture fraction and mixture fraction variance equations.
Can anyone help me understand why we need fvc apart from the fact that it is an explicit equation? I have seen that for calculating gradient or with source terms (Sp), it is always accompanied with fvc. Why is it so?
Also what is happening when the Sp term is introduced.
Thanks in advance
dj18deepak is offline   Reply With Quote
Old   December 26, 2019, 05:41
Deepak J
I am trying to implement mixture fraction and mixture fraction variance conserved transport equations to simulate a simple propane non reacting jet flame. The simulation is well and running with slight amount of deviations from experimental data while using small value of grading in the x and y directions (8 and 8 resp). The problem i am facing is that with higher values of grading (12 in x-direction and 15 in y-direction), even though the velocity, temperature and all profiles are evolving, the mixture fraction and mixture fraction variance variables are having very low values of the order of 10^-70 (for mixture fraction). What might be the possible causes of the error. Kindly help me. I am a beginner.
Code
fvScalarMatrix mifEqn
fvm::ddt(rho, mif)
+ fvm::div(phi, mif)
- fvm::laplacian(turbulence->mut()/0.7, mif)
mifEqn.relax();
mifEqn.solve();
fvScalarMatrix mifvarEqn
fvm::ddt(rho, mifvar)
+ fvm::div(phi, mifvar)
- fvm::laplacian(turbulence->mut()/0.7, mifvar)
- 2.86*turbulence->mut()*magSqr(fvc::grad(mif))
+ 2*rho*(turbulence->epsilon()/(turbulence->k()+k_small))*mifvar
mifvarEqn.relax();
mifvarEqn.solve(mesh.solver("mifvar"));
fvSchemes dictionary
ddtSchemes
default Euler;
gradSchemes
default cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phiU,p) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,K) Gauss limitedLinear 1;
div(phi,k) Gauss limitedLinear 1;
div(phi,H) Gauss limitedLinear 1;
div(phi,Yi_h) Gauss limitedLinear 1;
div(phi,mif) Gauss limitedLinear 1;
div(phi,mifvar) Gauss limitedLinear 1;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
fluxRequired
p;
fvSolution dictionary
solvers
"rho.*"
solver diagonal;
p
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.1;
pFinal
$p;
tolerance 1e-6;
relTol 0.1;
"(U|h|k|epsilon)"
solver PBiCGStab;
preconditioner DILU;
tolerance 1e-6;
relTol 0.1;
"(U|h|k|epsilon|mif)Final"
$U;
relTol 0.1;
"(mif|mifvar)"
solver PBiCG;
tolerance 1e-07;
relTol 0.;
Yi
$hFinal;
relaxationFactors
fields
p 0.4;
rho 0.5;
equations
U 0.4;
k 0.5;
epsilon 0.5;
//H 0.5;
mif 0.5;
mifvar 0.2;
PIMPLE
momentumPredictor no;
nOuterCorrectors 1;
nCorrectors 2;
nNonOrthogonalCorrectors 0;
Kindly note: mif is mixture fraction and mifvar is mixture fraction variance
Thanks and regards
Deepak J
Old   December 26, 2019, 09:01
Tobi's Avatar
Tobias Holzmann
Hi, check out my repository of the flamelet model. There you see how it has to be implemented.
Keep foaming,
Tobias Holzmann
Old   December 26, 2019, 09:47
Deepak J
Hi Tobi,
Thanks for the reply. Will definitely check the same.
Thanks and regards
Deepak
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
What is mixture fraction variance? Hugo FLUENT 3 April 20, 2015 21:24
the 2 equation of flamelet model. AdidaKK CFX 0 October 17, 2009 05:33
