April 25, 2012, 04:50 |
interFoam and alphaEqn.H
Pablo
Why in alphaEqn.H is it not added alpha1 = max(min(alpha1, scalar(1)), scalar(0)); i mean this artificial bounded? Thanks |
April 25, 2012, 05:55 |
Pablo Higuera
Rep Power: 19 |
Hi
MULES solver ensures boundedness, that is why the last 2 inputs are 0 and 1, the bounds of alpha1. This is achieved by the use of limiters. The final result may show values greater than 1 or lower than 0, but with differences of the order of 10^-5, which is negligible. Regards |
May 1, 2012, 08:52 |
Santiago Marquez Damian
Rep Power: 23 |
Using an artificial bounding of this kinds leads to a non-phase-preserving algorithm due it 'cuts' with having in account the conservative properties of the alpha equation. In other words you will lose or gain mass.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
May 7, 2012, 13:57 |
Pablo
But looking for steady state loss or gain mass is not going to be relevant or yes?
Thanks |
May 8, 2012, 12:59 |
Rep Power: 23 |
Hhmm, I don't know, but since the solver is unsteady probably it will blow up before reach the steady state due mass preservation problems.
Regards.
March 28, 2016, 10:47 |
Saideep
Rep Power: 12 |
Hi guys,
I guess this is the most relevant thread I found to post the following question and hope anyone of you could help me out. The alphaEqn.H file has evolved from 2.2 version to 2.3 version. I can understand the 2.2 version of the code but I cant follow most part of the 2.3 version of alphaEqn. Can you help me out? What does the following code indicate? fvScalarMatrix alpha1Eqn ( fv::EulerDdtScheme<scalar>(mesh).fvmDdt(alpha1) + fv::gaussConvectionScheme<scalar> ( mesh, phi, upwind<scalar>(mesh, phi) ).fvmDiv(phi, alpha1) ); The later part is from the older version for advection of alpha with velocity and relative velocity terms. I tried to use the older version into this but alpha is no more bounded between 0 and 1. Thanks; Saideep |
April 16, 2016, 21:00 |
Rep Power: 23 |
Hi Saideep, the new version of alphaEqn is based on operator splitting techniques to obtain a semi-implicit solver. The code you posted corresponds to the first-order bounded predictor of alpha which is lately corrected by a high-order corrector:
http://www.openfoam.org/version2.3.0/multiphase.php Regards.
compressibilty effect in alphaEqn.H | nimasam | OpenFOAM | 21 | February 20, 2018 16:30 |
Small time step in interFoam | Andrea_85 | OpenFOAM | 35 | October 31, 2017 22:14 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Vof method in interFoam | Andrea_85 | OpenFOAM | 10 | February 17, 2011 04:41 |
