how to rename a field defined from others fields ?
Old   April 25, 2012, 09:34
Default how to rename a field defined from others fields ?
Cyp
Cyprien
Cyp is on a distinguished road
Hi!
I defined a symmetric tensor field symGradU from a field U
volSymmTensorField symGradU = twoSymm(fvc::grad(U));
When I plot the field name using
Info << "Field symGradU name = " << symGradU.name() << endl;
I get
Field symGradU name = twoSymm(grad(U))
I want to change this name ("symGradU"), in particular to write the output correctly. I tried
 symGradU.name() = "symGradU" ;
but it doesn't work.
Do you know a simple manner to rename a field ??
Regards,
Cyp
Cyp is offline   Reply With Quote
Old   April 26, 2012, 10:50
David Gaden
marupio is on a distinguished road
You can do it during construction, (though it must be possible to do it afterwards too...). From GeometricField.H:
        //- Construct as copy resetting IO parameters
        GeometricField
            const IOobject&,
            const GeometricField<Type, PatchField, GeoMesh>&
        //- Construct as copy resetting name
        GeometricField
            const word& newName,
So you could use:
        "symmGradU",
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   April 26, 2012, 11:32
Cyp
Cyprien
Thank you very much ! It is exactly what I was looking for !
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Need help evaluating field by interpolation with a "lookup table" JohnRHawk OpenFOAM Programming & Development 2 June 28, 2011 13:27
Vector Fields and Operators on the Boundary Noggin OpenFOAM Programming & Development 3 February 17, 2011 10:43
writing fields with field types "kqRWallFunction" ubaid OpenFOAM 0 October 2, 2010 14:22
Flow field measurement in turbomachinery! Wanlai Lin Main CFD Forum 3 September 3, 1999 12:06
