Home > Forums > OpenFOAM Programming & Development
Reading OpenFOAM Variables
Old   April 26, 2012, 10:19
Default Reading OpenFOAM Variables
sandip
vmsandip2011 is on a distinguished road
Hi all,
I am new to OpenFOAM source code.
I wanted to know where in OpenFOAM code the variables are read.
e.g. if you open the createFields.H for icoFoam you will find
Info<< "Reading transportProperties\n" << endl;
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
dimensionedScalar nu
transportProperties.lookup("nu")
Info<< "Reading field p\n" << endl;
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
I hope these lines are reading the P, U and transportProperties directory.
I tried to debug in createFields.h file but I am not able to reach in source files
where the P,U and nu and their respective dimensions are read.
Can anybody tell me about the source files where OpenFoAM reads its variables.
with regards.
vmsandip2011 is offline   Reply With Quote
Old   April 26, 2012, 10:32
David Gaden
marupio is on a distinguished road
OpenFOAM reinvents the wheel... it has its own input and output stream classes defined. Not sure why you want to go that deep into the OpenFOAM library.
The two objects you list above are different. transportProperties is an IOdictionary, p is a volScalarField, which is actually a typedef of GeometricField. If you look through these two classes, you will see they have many constructors defined. The ones being used above are "read constructors", although it may not be explicitly mentioned in the source. These constructors find a file in your case directory and look up all the information they need from this file. So, the constructors only require the information necessary to locate the file, and possible references to other objects they may need, such as volScalarField needs the mesh object. I believe most read constructors use operator>>, so you could look at this operator in each class.
You might want to read up on the objectRegistry to find out more.
http://openfoamwiki.net/index.php/Op...objectRegistry
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   June 5, 2012, 12:16
flowris is on a distinguished road
I am trying to use the forces class to write a mesh motion class. When initializing a forces object, one needs the objectRegistry. The constructor is
        forces
            const word& name,
            const objectRegistry&,
            const dictionary&,
            const bool loadFromFiles = false
But I don't know how I can refer to this . Any help?
flowris is offline   Reply With Quote
Old   June 6, 2012, 09:42
Frederic Collonval
Location: Technische Universitaet Munich - Lehrstuhl fuer Thermodynamik
fcollonv is on a distinguished road
The "mesh" object inherits from objectRegistry. So just pass the object "mesh".
Actually in
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
mesh
The third argument of IOobject (i.e. "mesh") is a constant reference to the objectRegistry; the constructor called is:
IOobject ( const word& name, const fileName& instance, const objectRegistry& registry, readOption r=NO_READ, writeOption w=NO_WRITE, bool registerObject=true );Good luck
Frederic Collonval
Technische Universität München
Thermodynamics Dpt.
fcollonv is offline   Reply With Quote
Old   June 6, 2012, 11:20
Thank you very much for this tip. I cannot pass mesh as argument, because it is not (yet) in my class. When I do
    forces f("forces", mesh, forcesDict);
I get
hppGgiFvMesh.C:358: error: ‘mesh’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/hppGgiFvMesh.o] Error 1
From which file did you quote?
Thread Tools
Trackbacks are On
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
reading "global" variables in a UDF macro? bawfuls Fluent UDF and Scheme Programming 1 July 1, 2010 21:22
openfoam 1.5-dev on opensuse10.3-64bit anon_c OpenFOAM 2 December 4, 2009 01:33
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
