Home > Forums > OpenFOAM Programming & Development
if statement for volScalarField
Like Tree1Likes
  • 1 Post By Bernhard
Old   April 28, 2012, 16:37
Question if statement for volScalarField
reza
sasookey is on a distinguished road
hi
i'm a new user of openFoam, i try to do something when a volScalarFied like p is in the specific number like smaller than 1 i tried this in solver.
if ( p < 1)
when p is volScalarField and i got som error for operator <
thanks to help me.
sasookey is offline   Reply With Quote
Old   April 29, 2012, 04:27
Bernhard
Bernhard is on a distinguished road
It depends a bit of what you want to do precisely. It is always a good idea to carefully read the errormessages. If you don't understand them, it is still worth to post them in a thread.
See also: Instruction if
sasookey likes this.
Bernhard is offline   Reply With Quote
Old   April 29, 2012, 05:56
Smile
reza
Thanks dear Bernhard, you got me and my problem has been solved.
Old   June 14, 2016, 14:55
Exclamation
Rimsha
block is on a distinguished road
Hi guys i am trying to implement a if loop in one of the libraries of interFoam where a variable called "kappaf" is depend on the alpha1f value, where i want to impose a condition where kappaf is alpha1f * DI for alpha1f >0.5 or zero if alphaf < 0.5.
I have written the loop
I am getting this error
I am new to openfoam and C++ coding so not familiar with how to write this.
Kind Regards
Rimsha
block is offline   Reply With Quote
Old   June 15, 2016, 13:40
David Gaden
marupio is on a distinguished road
You can't put a for loop within a function call like that.
return tmp<surfaceScalarField>
    new surfaceScalarField
        // This is a function call - specifically, a constructor
You could create your field first, then modify its values. Also, the if / else if / else syntax is:
if (condition)
    // statements
else if (anotherCondition)
    // statements
else
    // statements
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   June 17, 2016, 12:32
Rimsha
if (condition)
    // statements
    // statements
else
    // statements
Thank you so much for helping. I have taken your advice and imposed the for loop just before the equation instead and it works fine.
Below is the procedure i followed.
I imposed the two diffusion coefficients in create fields for the solver
wrote this loop before the equation that i imposed in runtime.
In the above loop i am trying to switch between diffusion coefficient depending on the cell face value of the alpha (a phase volume fraction in interFoam).
Hope this helps anyone trying to do something similar.
Thanks again.
Rimsha
Thread Tools
Trackbacks are On
if statement for volScalarField AnjaMiehe OpenFOAM Programming & Development 2 April 24, 2012 07:01
If Statement Zaktatir CFX 5 June 19, 2010 06:09
Weak statement for Galerkin Method rugabug Main CFD Forum 0 March 26, 2010 20:19
Problem Statement balkrishna Main CFD Forum 0 October 6, 2009 23:55
marking statement in Latex mike Main CFD Forum 0 October 8, 2006 12:01
