modify cyclic b.c.
Old   May 8, 2012, 09:08
Default modify cyclic b.c.
Adrian Zenklusen
Adrian83 is on a distinguished road
I'm simulating the spreading of a contaminant from a point source in a fully developed duct flow. So I would like to apply the cyclic boundary conditions (with the channelFoam solver) for velocities and pressure but not for the concentration of the contaminant (once the contaminant is at the outlet, it should not be feed in at the inlet)
So far I used directMapped (map velocities and pressure of the cross section in the middle to the inlet) at the inlet and zeroGradient at the outlet for pressure and velocities. For the contaminant concentration I used zeroGradient at the outlet and fixedValue (=0) at the inlet. So my duct is actually longer than I need (the influence of the zeroGradient boundary condition at the outlet requires that the duct is long enough).
I'm wondering, if it's possible to use cyclic boundary conditions for pressure and velocities but not for the contaminants concetration. Acutally I want to set the concentration to 0 at the inlet.
Could someone tell me which files I have to modify?
Adrian83 is offline   Reply With Quote
Old   June 4, 2012, 12:44
Jian Zhong
zxj160 is on a distinguished road
I also met the same problem. Did you solve it? If so, could you please tell me how to do that?
zxj160 is offline   Reply With Quote
Old   June 6, 2012, 06:33
Adrian Zenklusen
Unfortunately not. I tried to modify fvScalarMatrix, but with no success.
Old   July 2, 2012, 11:39
Jian Zhong
Hi, can you use 'directMaped' BC for cyclic inlet and outlet patches?
My best regards,
Jian
Cyclic B.C -interDyMFOAM-Gambit Mesh-Parallel farhagim OpenFOAM 3 March 12, 2011 23:29
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
mass flux and temperature b.c with cyclic conditions David_010 OpenFOAM 0 March 5, 2010 05:14
cyclic B.C. in Star-LT hank Siemens 2 September 22, 2006 10:02
question on cyclic B.C. for temperature Jiaying Xu Siemens 1 February 27, 2003 06:13
