coding of antal lubrication force
Old   May 15, 2012, 17:06
Default coding of antal lubrication force
Jeong Kim
enoch is on a distinguished road
nw is the unit normal pointing away from the wall.
v1-v2 is is the relative velocity difference between phases, in the plane of the nearby wall surface (that is, orthogonal to nw).
yw is the distance to the nearest wall.
magUr = mag(Ur);
sqrmagUr = sqr(magUr);
volScalarField Cwl = max(0.0, (Cw1/da)+(Cw2/postion.y);
volVectorField wallLubForce = Cwl*alpha*rhob*sqrmagUr*position.y.normal
postion.y is yw.
position.y.normal is nw.
How can I express yw and nw in the foam?
enoch is offline   Reply With Quote
Old   May 16, 2012, 01:57
Bernhard
Bernhard is on a distinguished road
You can use the files that are located in src/finiteVolume/fvMesh/wallDist . I think you can get wall distance and normal vectors from these files.
For synthax you can have a look at LES turbulence model vanDriestDelta, where the wall distance is used. For the normal vectors I don't know an example, but the reflectionVectors files seem to be what you need.
Bernhard is offline   Reply With Quote
Old   May 17, 2012, 03:38
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Never tested them but you can find the Antal/Frank models here:
https://github.com/lrm29/multiphaseSurfaceForces
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   May 18, 2012, 13:52
Jeong Kim
I'm sorry for my repeating question. I'm still not not sure how I can get a normal distance and a wall normal unit vector. Here is what I did.
I Included two header files in the main code.
#include "wallDistReflection.H"
#include "wallDist.H"
I updated option.
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
-lfiniteVolume \
-lmeshTools
In the code,
// Distance to nearest wall: wallDist.H
volScalarField yDist = y.n();
// Wall normal unit vector: wallDistReflection.H
volScalarField Cwl = myScalar/yDist;
Info << "Cwl= " << Cwl;
But I've got compilation errors shown below. How can get a yDist and a normal unit vector?
Making dependency list for source file icoFoamMod.C
SOURCE=icoFoamMod.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/jeong/OpenFOAM/openfoam210/src/finiteVolume/lnInclude -I/home/jeong/OpenFOAM/openfoam210/src/meshTools/lnInclude -IlnInclude -I. -I/home/jeong/OpenFOAM/openfoam210/src/OpenFOAM/lnInclude -I/home/jeong/OpenFOAM/openfoam210/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/icoFoamMod.o
/home/jeong/OpenFOAM/openfoam210/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’:
/home/jeong/OpenFOAM/openfoam210/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’
/home/jeong/OpenFOAM/openfoam210/src/finiteVolume/lnInclude/readPISOControls.H:12:16: warning: unused variable ‘momentumPredictor’
/home/jeong/OpenFOAM/openfoam210/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’
In file included from icoFoamMod.C:131:0:
exportDataLastTime.H:14:25: error: ‘y’ was not declared in this scope
exportDataLastTime.H:22:38: error: ‘struct Foam::volScalarField’ has no member named ‘n’
make: *** [Make/linux64GccDPOpt/icoFoamMod.o] Error 1
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Tomiyama wall lubrication force Edy OpenFOAM 10 December 13, 2010 11:41
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Adding Van der Waals force by coding UDF Long Sang FLUENT 1 June 23, 2008 07:44
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
