Home > Forums > OpenFOAM Programming & Development
pointVolInterpolation, How to use it?
Old   May 30, 2012, 15:46
Default pointVolInterpolation, How to use it?
Jorge Meneses
Goab is on a distinguished road
Hello Foamers,
Possibly this is well known but I'm having a hard time making it work.
I've been searching throughout the forum and I've seen that apparently pointVolInterpolation works correctly ( what happened to pointVolInterpolation?) I already found it and I've been reading the code, however I haven't been able to use it.
I'm using simpleFoam and what I want to do is to take a volVectorField, get its points using volPointInterpolation and change them by multiplying them by a factor and adding some constants to each component (x,y,z), and finally, after that get again a volVectorField using those values.
What I have so far is:
volVectorField alpha
        IOobject
            "alpha",
            runTime.timeName(),
            mesh,
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
        mesh
pointField P = interpVolPoint.interpolate(alpha);
point& pt = P[pointI]
forAll(P, pointI)
            double px=3.0*pt.x()+15;
            double py=2.0pt.y()+16;
            double pz=pt.z()+14;
volVectorField beta
        IOobject
            "beta",
            runTime.timeName(),
            mesh,
        mesh
pointField pt = pointVolInterpolation interpPointVol (mesh);
beta = interpPointVol.interpolate(pt);
When I use volPointInterpolation, even when I change the values, it works perfectly, however when I try to create again the volVectorField out of those values, it crashes.
Hope you can help me.
Thank you.
Goab is offline   Reply With Quote
Thread Tools
Trackbacks are On
