GGI and Topological changes - checkMesh fails |
June 18, 2012, 10:35 |
Klaus
Hi foamers,
I am working to combine the GGI interface and topological changes of the mesh in OpenFOAM 1.6 ext. In the video you can see my test case, a cylinder where the right (or front) part is growing (translation) in the negative z-direction whereas the left (or back) part is rotating. https://dl.dropbox.com/u/86131187/GgiTopoChange.avi Calculation was done with the transientSimpleDyMFoam solver on a single processor, at first sight the results look ok. Post processing works fine with with the paraFoam utility. But running checkMesh gives the following error Code:
--> FOAM FATAL ERROR: Problem with patch-to zone addressing: some patch faces not found in interpolation zone From function void ggiPolyPatch::calcZoneAddressing() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 103. FOAM aborting Aborted Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-ext-f3027b3161e4 Exec : checkMesh Date : Jun 18 2012 Time : 13:29:33 Host : Brain PID : 8352 Case : /home/ak113859/OpenFOAM/ak113859-1.6-ext/run/GgiTest/GgiWithTopoChanger nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 86 could not load /home/ak113859/OpenFOAM/ak113859-1.6-ext/lib/linux64GccDPOpt/libipimdynamicFvMesh.so: undefined symbol: _ZTIN4Foam17topoChangerFvMeshE Create polyMesh for time = 0 void polyMesh::initMesh() : initialising primitiveMesh face zone name: screw face zone index: 2 size: 2784 start: 121632 startLabel: 0 Initializing the GGI interpolator between master/shadow patches: outletScrew-7/inletChamber-10 From function void GGIInterpolation<MasterPatch, SlavePatch>::calcAddressing() const in file lnInclude/GGIInterpolationWeights.C at line 94 Evaluation of GGI weighting factors: From function GGIInterpolation::findNonOverlappingFaces in file lnInclude/GGIInterpolationWeights.C at line 633 : Found 0 non-overlapping faces for this GGI patch From function GGIInterpolation::findNonOverlappingFaces in file lnInclude/GGIInterpolationWeights.C at line 633 : Found 0 non-overlapping faces for this GGI patch Largest slave weighting factor correction : 0.0105776 average: 0.000376867 Largest master weighting factor correction: 0.0105228 average: 0.00035835 face zone name: chamber face zone index: 0 size: 2784 start: 124416 startLabel: 0 polyMesh::globalData() const : Constructing parallelData from processor topology polyMesh::readUpdateState polyMesh::readUpdate() : Updating mesh based on saved data. Faces instance: old = "0" new = "0" Points instance: old = "0" new = "0" No change Time = 0 void polyMesh::clearGeom() : clearing geometric data void polyMesh::clearAddressing() : clearing topology polyMesh::globalData() const : Constructing parallelData from processor topology Mesh stats all points: 48490 live points: 48490 all faces: 130560 live faces: 130560 internal faces: 115968 cells: 41088 boundary patches: 7 point zones: 0 face zones: 3 cell zones: 2 Overall number of cells of each type: hexahedra: 41088 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology wallScrew-4 2784 2833 ok (non-closed singly connected) wallBarrel-5 1536 1632 ok (non-closed singly connected) inletScrew-6 1344 1440 ok (non-closed singly connected) outletScrew-7 2784 2833 ok (non-closed singly connected) inletChamber-10 2784 2833 ok (non-closed singly connected) wallChamber-11 576 672 ok (non-closed singly connected) front-12 2784 2833 ok (non-closed singly connected) Checking geometry... This is a 3-D mesh Overall domain bounding box (-0.00147418 -0.00147418 -0.00141191) (0.00147418 0.00147418 0.000669233) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Mesh (non-empty, non-wedge) dimensions 3 Boundary openness (-2.33671e-18 -1.2622e-19 1.17466e-16) Threshold = 1e-06 OK. Max cell openness = 3.07599e-16 OK. Max aspect ratio = 6.80908 OK. Minumum face area = 4.34507e-10. Maximum face area = 9.66699e-09. Face area magnitudes OK. Min volume = 2.96127e-14. Max volume = 4.2747e-13. Total volume = 9.5907e-09. Cell volumes OK. Mesh non-orthogonality Max: 34.5777 average: 3.28214 Threshold = 70 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.80492 OK. Mesh OK. polyMesh::readUpdateState polyMesh::readUpdate() : Updating mesh based on saved data. Faces instance: old = "0" new = "0.005" Points instance: old = "0" new = "0.005" Topological change void polyMesh::clearGeom() : clearing geometric data void polyMesh::clearAddressing() : clearing topology void polyMesh::setInstance(const fileName& inst) : Resetting file instance to "0.005" void polyMesh::setMotionWriteOpt(IOobject::writeOption) Setting motion writeOpt to 0 void polyMesh::setTopoWriteOpt(IOobject::writeOption) Setting topo writeOpt to 0 void polyMesh::initMesh() : initialising primitiveMesh face zone name: screw face zone index: 2 size: 2784 start: 129936 startLabel: -1 --> FOAM FATAL ERROR: Problem with patch-to zone addressing: some patch faces not found in interpolation zone From function void ggiPolyPatch::calcZoneAddressing() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 103. FOAM aborting Aborted Code:
... screw { type faceZone; faceLabels List<label> 2784 ( 129936 129937 ... 132719 ) ; flipMap List<bool> 2784{1}; } ) faceZone at time step 0 Code:
... screw { type faceZone; faceLabels List<label> 2784 ( 121632 121633 ... 124415 ) ; flipMap List<bool> 2784{1}; } ) Someone out there who can shed some light on this issue? Best regards, Klaus |
June 19, 2012, 12:14 |
is it a bug...
Klaus
some update to my post above
running checkMesh utility for a single time step works perfect Code:
checkMesh -time 0 Code:
checkMesh -time 0.005 Today i tried to find out what's going wrong. In the file polyMeshIO.C the line Code:
boundary_.calcGeometry(); Code:
... // Calculate topology for the patches (processor-processor comms etc.) boundary_.updateMesh(); // Calculate the geometry for the patches (transformation tensors etc.) boundary_.calcGeometry(); // Derived info bounds_ = boundBox(allPoints_); geometricD_ = Vector<label>::zero; solutionD_ = Vector<label>::zero; // Zones pointZoneMesh newPointZones ( IOobject ( "pointZones", facesInst, meshSubDir, *this, IOobject::READ_IF_PRESENT, IOobject::NO_WRITE, false ), *this ); label oldSize = pointZones_.size(); if (newPointZones.size() <= pointZones_.size()) { pointZones_.setSize(newPointZones.size()); } // Reset existing ones forAll (pointZones_, czI) { pointZones_[czI] = newPointZones[czI]; } // Extend with extra ones pointZones_.setSize(newPointZones.size()); for (label czI = oldSize; czI < newPointZones.size(); czI++) { pointZones_.set(czI, newPointZones[czI].clone(pointZones_)); } pointZones_.setSize(newPointZones.size()); forAll (pointZones_, pzI) { pointZones_[pzI] = newPointZones[pzI]; } faceZoneMesh newFaceZones ( IOobject ( "faceZones", facesInst, meshSubDir, *this, IOobject::READ_IF_PRESENT, IOobject::NO_WRITE, false ), *this ); oldSize = faceZones_.size(); if (newFaceZones.size() <= faceZones_.size()) { faceZones_.setSize(newFaceZones.size()); } // Reset existing ones forAll (faceZones_, fzI) { faceZones_[fzI].resetAddressing ( newFaceZones[fzI], newFaceZones[fzI].flipMap() ); } // Extend with extra ones faceZones_.setSize(newFaceZones.size()); for (label fzI = oldSize; fzI < newFaceZones.size(); fzI++) { faceZones_.set(fzI, newFaceZones[fzI].clone(faceZones_)); } cellZoneMesh newCellZones ( IOobject ( "cellZones", facesInst, meshSubDir, *this, IOobject::READ_IF_PRESENT, IOobject::NO_WRITE, false ), *this ); oldSize = cellZones_.size(); if (newCellZones.size() <= cellZones_.size()) { cellZones_.setSize(newCellZones.size()); } // Reset existing ones forAll (cellZones_, czI) { cellZones_[czI] = newCellZones[czI]; } // Extend with extra ones cellZones_.setSize(newCellZones.size()); for (label czI = oldSize; czI < newCellZones.size(); czI++) { cellZones_.set(czI, newCellZones[czI].clone(cellZones_)); } ... Code:
... // Zones pointZoneMesh newPointZones ( IOobject ( "pointZones", facesInst, meshSubDir, *this, IOobject::READ_IF_PRESENT, IOobject::NO_WRITE, false ), *this ); label oldSize = pointZones_.size(); if (newPointZones.size() <= pointZones_.size()) { pointZones_.setSize(newPointZones.size()); } // Reset existing ones forAll (pointZones_, czI) { pointZones_[czI] = newPointZones[czI]; } // Extend with extra ones pointZones_.setSize(newPointZones.size()); for (label czI = oldSize; czI < newPointZones.size(); czI++) { pointZones_.set(czI, newPointZones[czI].clone(pointZones_)); } pointZones_.setSize(newPointZones.size()); forAll (pointZones_, pzI) { pointZones_[pzI] = newPointZones[pzI]; } faceZoneMesh newFaceZones ( IOobject ( "faceZones", facesInst, meshSubDir, *this, IOobject::READ_IF_PRESENT, IOobject::NO_WRITE, false ), *this ); oldSize = faceZones_.size(); if (newFaceZones.size() <= faceZones_.size()) { faceZones_.setSize(newFaceZones.size()); } // Reset existing ones forAll (faceZones_, fzI) { faceZones_[fzI].resetAddressing ( newFaceZones[fzI], newFaceZones[fzI].flipMap() ); } // Extend with extra ones faceZones_.setSize(newFaceZones.size()); for (label fzI = oldSize; fzI < newFaceZones.size(); fzI++) { faceZones_.set(fzI, newFaceZones[fzI].clone(faceZones_)); } cellZoneMesh newCellZones ( IOobject ( "cellZones", facesInst, meshSubDir, *this, IOobject::READ_IF_PRESENT, IOobject::NO_WRITE, false ), *this ); oldSize = cellZones_.size(); if (newCellZones.size() <= cellZones_.size()) { cellZones_.setSize(newCellZones.size()); } // Reset existing ones forAll (cellZones_, czI) { cellZones_[czI] = newCellZones[czI]; } // Extend with extra ones cellZones_.setSize(newCellZones.size()); for (label czI = oldSize; czI < newCellZones.size(); czI++) { cellZones_.set(czI, newCellZones[czI].clone(cellZones_)); } // Calculate topology for the patches (processor-processor comms etc.) boundary_.updateMesh(); // Calculate the geometry for the patches (transformation tensors etc.) boundary_.calcGeometry(); // Derived info bounds_ = boundBox(allPoints_); geometricD_ = Vector<label>::zero; solutionD_ = Vector<label>::zero; ... Question to the experts: is it allowed to do that or are there any side effects which i should be aware of? Comments would be fine. Best regards, Klaus |
June 19, 2012, 12:37 |
Sandeep Menon
Rep Power: 25 |
Hmm... looks like the zones were written to disk with addressing prior to topo-changes. This may not be an actual problem, since you say that the solution looks fine, but an issue where inconsistent addressing is written to disk. Still needs to be fixed though...
June 20, 2012, 06:30 |
#4 | |
Klaus
t=0; Code:
... screw { type faceZone; faceLabels List<label> 2784 ( 121632 121633 ... 124415 ) ; flipMap List<bool> 2784{1}; } .... Code:
... screw { type faceZone; faceLabels List<label> 2784 ( 129936 129937 ... 132719 ) ; flipMap List<bool> 2784{1}; } ... The problem arises when the mesh is read from disk. Best, Klaus |
November 10, 2019, 06:48 |
#5 | |
Hojatollah Gholami
Rep Power: 7 |
Dear foamer
Did you involve with this error? Quote:
Quote: // Create neighbouring face centres using interpolation if (master()) { const label shadowID = shadowIndex(); // Get the transformed and interpolated shadow face cell centers reconFaceCellCentresPtr_ = new vectorField ( interpolate ( boundaryMesh()[shadowID].faceCellCentres() - boundaryMesh()[shadowID].faceCentres() ) + faceCentres() ); } else { FatalErrorIn("void ggiPolyPatch::calcReconFaceCellCentres() const") << "Attempting to create reconFaceCellCentres on a shadow" << abort(FatalError); } Do you know, why this error appears? when I use cyclicGgi for top and bottom of rectangular domain, the problem appear when running simulation. |
Create a GeometricField of a given type on given patch? | philippose | OpenFOAM Programming & Development | 4 | August 12, 2013 13:41 |
engine Simulations with GGI instead of Sliding Interface | abminternet | OpenFOAM | 3 | April 30, 2013 04:41 |
GGI together with topological changes... | kalle | OpenFOAM Running, Solving & CFD | 6 | May 7, 2012 14:50 |
GGI modeling | shavkat | OpenFOAM Running, Solving & CFD | 2 | December 22, 2010 05:39 |
