June 21, 2012, 06:00 |
rotatingWallVelocity normal to wall
Robert Castilla
Rep Power: 17 |
I am working in a simulation with dynamic mesh. But, previously, I wanted to make the stationary simulation. A wall is rotating, and I wonder if I could use the rotatingWallVelocity. I tried with pimpleFoam, and the results are not correct (very high velocities in some cells, near to the rotating wall). Even with potential Foam, it gives velocity zero (no wall velocity?) around the domain, except on the wall. I checked the rotatingWallVelocity BC source and I found that: // Remove the component of Up normal to the wall // just in case it is not exactly circular const vectorField n(patch().nf()); vectorField::operator=(Up - n*(n & Up)); Does it mean that only the tangencial wall velocity is considered for the fluid motion? Why? Anyway, I will try to remove this constraint, and I see what happens... but I would like to know the reason of that. Thanks Robert |
June 21, 2012, 15:21 |
#2 | |
Kyle Mooney
Rep Power: 17 |
April 2, 2024, 09:29 |
#3 | |
S03r3n
Rep Power: 2 |
Can you share your experience/ results? Thanks in advance! |
April 3, 2024, 03:22 |
#4 | |
Robert Castilla
Rep Power: 17 |
It was long time ago, and I don't remember now the details. But I think that we solved the problem finally, and it was published in the Journal of Fluids Engineering, of the ASME: Castilla, R., Gamez-Montero, P. J., Raush, G., & Codina, E. (2017). Method for fluid flow simulation of a gerotor pump using OpenFOAM. Journal of Fluids Engineering, 139(11), 111101. It was used to deform the mesh of a gerotor pump. Regards |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Wall Normal Temperature Gradient | Daniel Tanner | FLUENT | 6 | September 20, 2015 13:10 |
UDF to Access Wall Normal Concentration Gradient | Daniel Tanner | Fluent UDF and Scheme Programming | 4 | February 18, 2015 14:35 |
momentum equation (Normal to wall) | kk | Main CFD Forum | 0 | July 2, 2006 23:13 |
Velocity gradient normal to a wall | ap | FLUENT | 0 | July 26, 2004 08:32 |
