Error compiling new drag model
Old   May 14, 2012, 10:30
Default Error compiling new drag model
Khurram
deep_seak is on a distinguished road
I am trying to introduce a new drag model in compressibleTwoPhaseEulerFoam solver but on executing the "wmake libso" command i get following error.
"No rule to make target 'dragModels/Mydragmodel/Mydragmodel.dep' , needed by 'Make/linuxGccDPOpt/dependencies' . Stop."
Please help me in this....
Thanks..
deep_seak is offline   Reply With Quote
Old   May 14, 2012, 18:01
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Have you tried running 'wclean' first? Also, what does the 'Make/files' contain?
kmooney is offline   Reply With Quote
Old   May 15, 2012, 09:16
Khurram
Yes, i have tried running wclean first but of no use. The Make/files within the "interfacialModles" contains the declaration of different heat transfer and drag models which can be used. I have added the declaration for my drag model in it.
Old   June 27, 2012, 04:55
wided
wiedangel is on a distinguished road
sometimes you need to check if the *.C file has the same name as you gave your executable in the "file" document.
Good luck
wiedangel is offline   Reply With Quote
Old   June 27, 2012, 06:41
Disabled
anon_a is on a distinguished road
Sometimes you may also need to use a "make*" command in order to add your model to the tables containing the list of available models (I think these are called the runtime tables or something similar. But I could be very wrong).
For example, I frequently use the dsmcFoam solver. There exist various models for the inflow of molecules. If I want to make a new one, I should not only copy the directory closest to my case but I should add an entry in
src/lagrangian/dsmc/parcels/derived/dsmcParcel/makeDsmcParcelInflowBoundaryModels.C
so that it is known to the solver. Just check this file to see what I mean.
The easiest way to find what you need to do is to grep for an existing model.
E.g. if there was a "previousModel" you can just go to the main directory and type
grep -r previousModel ./
This should give you an idea of what is missing or what needs to be modified.
EDIT: Cool, I just realised this was a rather old post. Anyway, I hope someone will find it useful.
anon_a is offline   Reply With Quote
dependencies, drag, openfoam 2.1.0
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
drag calculation of a car model by phoenics mukut Phoenics 2 January 9, 2010 18:07
multiphase model and drag law Yasmail AKARIOUH FLUENT 0 April 29, 2008 07:44
multiphase flow modelling, Drag model Anant CFX 1 February 4, 2008 04:18
Laminar wing profiles and drag gregorv OpenFOAM Running, Solving & CFD 4 December 4, 2007 13:25
