-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   FCT/TVD in Volume of Fluid (interFoam) (http://www.cfd-online.com/Forums/openfoam-programming-development/104137-fct-tvd-volume-fluid-interfoam.html)
santiagomarquezd July 3, 2012 16:52
Hi, I've asked to a couple of members of the forum about this topic and now I want to open the discussion in order to find more people working on it. The question is:
1. Why interFoam integrates the alphaEqn using MULES (a Flux Corrected Transport based method) instead of the standard fvm operators (based on TVD)?
References will be appreciated. If I found some useful references I will post them.
Thx in advance
wyldckat July 3, 2012 17:43
Greetings Santiago,
Check the links on this wiki page: http://openfoamwiki.net/index.php/InterFoam
I fixed/updated most links, after I spotted that someone had tagged the page as having broken links.
Most of them are pointing to very old threads, so hopefully you can find vital information!
Best regards,
Bruno
santiagomarquezd July 3, 2012 23:11
Thanks Bruno for recalling these old threads. I read them a long time ago, but in this new reading I remembered that at the first time FOAM VOF didn't have a FCT based limiter. The first version used CICSAM I think, then interface compression appeared with gamma scheme, finally interface compression and linear term started to being solved using FCT (MULES).
My question is related with the reasons for the change.
Regards.
akidess July 4, 2012 03:41
As for CICSAM vs. MULES+interface compression, I believe a reason was that CICSAM would tend to align the interface with the mesh, whereas the latter keeps the interface sharp in a more smart way.
On a side note: At the OpenFOAM workshop 2012 there was a talk ("Libraries for 6-DOF Motion of the Floating Body") where the presenter had implemented CICSAM and HRIC into OpenFOAM and tested all of them. My impression was that their performance was very similar.
- Anton
santiagomarquezd July 6, 2012 10:42
Anton, Could you post the a link for this talk (if its available)? It would be valuable.
Regards.
akidess July 6, 2012 11:27
The talks are not available yet. Deadline for submission is 13.07., so soon after it should be online.
santiagomarquezd July 6, 2012 15:21
Ok, the comment was due we had lost the name of the conference/workshop/etc...
Originally Posted by akidess (Post 369685)
On a side note: At the there was a talk
Regards
akidess July 25, 2012 06:48
This is the talk I was referring to:
http://www.openfoamworkshop.org/2012...lks/LeeHeebum/
kathrin_kissling July 26, 2012 04:20
Hey guys,
check out the ship hydro library of Eric Patterson, which I think holds both.
It should be on the workshop USB stick, but you also can find it here
http://openfoam-extend.git.sourcefor...ydroSIG;a=tree
Best regards
Kathrin
RoE May 27, 2013 12:10
Originally Posted by kathrin_kissling (Post 373641)
Hey guys,
Best regards
Kathrin
Hi!
I am also interested in the CICSAM scheme. Unfortunately, the link does not work for me... Any idea where the code can be found now?
Best wishes,
Roland
wyldckat June 10, 2013 11:01
Greetings to all!
@Roland: FYI, the repository is back online and instructions for building this particular ShipHydroSIG repository can be found here: http://www.cfd-online.com/Forums/ope...tml#post432934 - post #2
Best regards,
Bruno
sharonyue July 15, 2013 22:35
Hi Akidess,
This link is not working, Do you have another one?
elvis July 16, 2013 02:33
http://openfoam-extend.sourceforge.n...tadt/OFW7.html
http://openfoam-extend.sourceforge.n...7_Program.html
http://sourceforge.net/projects/open...-Lee-OFW7.pptx
