Loop over cells per processor (parallel)
Old   July 7, 2012, 12:56
Default Loop over cells per processor (parallel)
Maxim
bme79 is on a distinguished road
Hi I got a problem and I have read a lot of posts on a different forums but still could not find a solution. I am doing something wrong. Could some one help me out.
Basically when I run my program on single processor it works fine but when on parallel it does not.
I am using the loop
forAll(mesh.C(),celli){
x = mesh.C()[celli].component(0);
y = mesh.C()[celli].component(1);
z = mesh.C()[celli].component(2);
arr = getnewvelocity(rho, U[celli].x(), U[celli].y(), U[celli].z(), p[celli]);
I found a post on this forum suggesting to use "reduce" command but it means that I send all data from all proc to one. I dont want this. I wan to go through all cells per processor.
Could some one give me an advise or example.
Thank you
bme79 is offline   Reply With Quote
Old   July 7, 2012, 18:32
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
I am using the loop
Well you can. But you must realize that in parallel this only goes through all the cells that are on this processors. But on all processors. Which makes it alright
Whether you want to do a reduce or not is irrelevant: it depends on what is happening in the location where you put the 7 points. May be that you don't need a reduce. May be that you need it after the loop.
Thank you
That is hard without knowing what the 7 points do
gschaider is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
