-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   A question about UEqn sonicFoam (http://www.cfd-online.com/Forums/openfoam-programming-development/104750-question-about-ueqn-sonicfoam.html)
lfgmarc July 14, 2012 20:25
Hi, I have a question about the UEqn implemented into sonicFoam, the code of the UEqn is:
fvVectorMatrix UEqn
    fvm::ddt(rho, U)
    + fvm::div(phi, U)
    + turbulence->divDevRhoReff(U)
My question is about the term that is computed from the turbulence model, i.e if K-epsilon model is selected, this term results:
tmp<fvVectorMatrix> kEpsilon::divDevRhoReff(volVectorField& U) const
    return
      - fvm::laplacian(muEff(), U)
      - fvc::div(muEff()*dev2(fvc::grad(U)().T()))
Initially I thought that it corresponded to
\nabla \cdot \left( \widetilde{\tau}-\bar{\rho}\widetilde{u^{''}u^{''}} \right) =
2\mu\left( \widetilde{S}-\frac{1}{3}\nabla\cdot\left(\widetilde{u}\right)\mathcal{I}\right)
+\left( 2\mu_{t}\left( \widetilde{S}-\frac{1}{3}\nabla\cdot\left(\widetilde{u}\right)\mathcal{I}\right) -
\frac{2}{3}\bar{\rho}\widetilde{k}\mathcal{I}
\right) (1)
but after examining the definition of dev2 in src/OpenFOAM/primitives/Tensor/TensorI.H
I found the following:
dev2(u)=u-\frac{2}{3}tr\left(u\right)
S is the rate-of-strain tensor given by
S=\frac{1}{2}\left(\nabla u + \left(\nabla u \right)^\mathrm{T} \right)
but according to the definition of DivDevRhoReff
divDevRhoReff = -\nabla^{2}\left(\mu_{eff} U\right)
-\nabla \cdot \left( dev2 \left(\mu_{eff}\left(\nabla U \right)^{\mathrm{T}}\right)\right)
And manipulating the expression (1) I conclude that the term
does not correspond to (1).
If someone can help me with my confusion about this term, I was very thankful
haze_1986 January 24, 2013 12:26
fvVectorMatrix UEqn
    fvm::ddt(rho, U)
    + fvm::div(phi, U)
    return
\right) (1)
Indeed, I was thinking it should be dev instead of dev2 as well if the explanation by poplar in http://www.cfd-online.com/Forums/ope...tml#post388688 is correct.
I hope I can find out what is wrong.
jens_klostermann February 15, 2013 09:07
the term
\nabla\cdot\left[2\mu\left( \widetilde{S}-\frac{1}{3}\nabla\cdot\left(\widetilde{u}\right)\mathcal{I}\right)
\right)\right]
is equal to
divDevRhoReff = -\nabla \cdot \left(\mu_{eff} \nabla U\right)
But I miss the term
\left(-
\right)
in
maybe someone can comment on this hidden term?
Jens
