polyMesh::findCell slow in parallel, but meshSearch::findCell sometimes fails
Old   November 13, 2015, 01:04
Default polyMesh::findCell slow in parallel, but meshSearch::findCell sometimes fails
Pete Bachant
pbachant is on a distinguished road
I am working on an fvOption source that moves around the mesh (actuator line), so I often need to lookup what cell an element is inside to read local velocity and cell volume. The code works great in serial using polyMesh::findCell, but this slows down a lot in parallel.
I tried replacing these calls with meshSearch::findCell(position, 0), and things get much faster, but sometimes cells are not found on any processors when run in parallel, which shouldn't be possible, right?
Any ideas on how I might either fix up meshSearch::findCell or speed up polyMesh::findCell?
Home | Twitter | GitHub
pbachant is offline   Reply With Quote
Old   August 5, 2017, 07:57
hamed eshraghi
hamedhiv is on a distinguished road
mesh search class does not support parallel proccessing.
you should use findCell function.
localCellId [Pstream::myProcNo()]= mesh().findCell(location);
reduce(localCellId, sumOp<List<label> >());
hamedhiv is offline   Reply With Quote
find cell, mesh, parallel
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
rhoCentralFoam solver with Slip BCs fails in Parallel Only JLight OpenFOAM Running, Solving & CFD 2 October 11, 2012 21:08
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 10:11
