Home > Forums > OpenFOAM Programming & Development
fvm::ddt(eigenVectors(S)) ????
Old   July 18, 2012, 10:37
Default fvm::ddt(eigenVectors(S)) ????
Hai Yu
yuhai is on a distinguished road
Dear Foamers,
In my transport equation, I need to calculate "fvm::ddt(eigenVectors(S))",
S here is a 3x3 tensor.
when I compile, system gives error:
no matching function for call to ‘ddt(Foam::tmp<Foam::GeometricField<Foam::Tensor<d ouble>, Foam::fvPatchField, Foam::volMesh> >)’
if I write:
S = eigenVectors(S);
fvm::ddt(S);
I can compile it. But in the latter way, it seems that I can not include the calculator "eigenVectors()" into the "SEqn.solve()".
Can you give some advice?
Thanks in advance.
H.Y.
yuhai is offline   Reply With Quote
Old   July 19, 2012, 04:43
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good day,
It looks like eigenVectors(S) returns a tmp format. So can you compile the following:
fvm::ddt( eigenVectors(S)() )
Please note the additional parentheses in the call. These strip the tmp-state of the return variable and yields a reference to a vol-field (that is instead of a tmp<vol-field>).
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   July 19, 2012, 09:59
Hai Yu
thank you for the fast help,
but I got new problems, (sorry, i am a so "new" C++ coder....)
I try to multiply in this way:
(eigenVectors(S)()) & fvm::ddt(eigenVectors(S)());
and got error as:
________________
SEqn.H:3: error: no match for ‘operator&’ in ‘Foam::eigenVectors(const Foam::GeometricField<Foam::Tensor<double>, PatchField, GeoMesh>&) [with PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]().Foam::tmp<T>:perator() [with T = Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>]() & Foam::fvm::ddt(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Tensor<double>]()’
________________
and can you give also some advice of it?
Thanks.
H.Y.
Old   July 19, 2012, 10:16
ngj
You are trying to do an inner product of a tensor (?) and the matrix coefficients in your linear set of equations.
That kind of operator is not supported by OpenFoam, at least not if you want to solve the 6 or 9 equations in a segregated approach, because you directly couple all the equations by that approach.
You might be able to address the problem with a block-coupled solver, however, that is far beyond my expertise, or you should formulate you problem as a segregated one.
Good luck,
Niels
Thread Tools
Trackbacks are On
