How to include additional variables in a LESdelta?
Old   July 23, 2012, 11:31
Default How to include additional variables in a LESdelta?
Jane L
Jane L is on a distinguished road
Hello!
Currently I'am programming my own DES turbulence model. Therefore I need to make a new version of maxDeltaxyz which includes u*dt and sqrt(k)*dt in addition to dx, dy, dz, where u is the magnitude of the velocity, dt is the timestep and k is the turbulent kinetic energy used in that turbulence model.
After trying one day, could anybody help me how to include which files so that I can use u, dt and k in maxDeltaxyz?
Thanks in advance for any help!!
Jane L is offline   Reply With Quote
Old   July 23, 2012, 12:06
Timo K.
timo_IHS is on a distinguished road
Have a look in this turbulence model (VLES)
OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/RAS/kOmegaSSTF
Best
timo_IHS is offline   Reply With Quote
Old   July 24, 2012, 04:36
Jane L
Thanks for your reply!
I downloaded OpenFOAM-1.6-ext and didn't find kOmegaSSTF in that src folder.
However the main changes to kOmegaSST are stated in the presentation "How to implement your own turbulence model" by Håkan Nilsson.
My problem is that those variables which can be used in a turbulence model aren't known by mymaxDeltaxyz (/home/user/OpenFOAM/user-2.1.1/src/turbulenceModels/LES/LESdeltas/maxDeltaxyz). Hence, when I write them into my code and try to compile, I recieve following output:
    error: ‘U_’ was not declared in this scope
    error: ‘runTime_’ was not declared in this scope
    error: ‘k_’ was not declared in this scope
So my quite basic question is how do I have to declare the variables in order to use them in mymaxDeltaxyz?
Best regards
Old   July 24, 2012, 07:35
Timo K.
Perhaps a IOobject helps!?
Old   July 24, 2012, 10:06
Jane L
ok, I think it works for now!
Thank you very much
Old   July 24, 2012, 10:21
Timo K.
Could you show some part of your code, perhaps it is interesting for other users too.
Old   July 25, 2012, 06:54
Jane L
yes, I will do that but I think I will wait until I have some validation results. Either I will post a running turbulence model or I will run into some problems and post a buggy code in order to get some help
so long
Old   November 1, 2012, 06:50
Jane L
Hi!
I finished the programming of the turbulence models. You find the necessary files in this thread:
http://www.cfd-online.com/Forums/ope...s-k-omega.html
best regards
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 15:15
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
