How to implement turbulence in one Solver???
Old   July 29, 2012, 05:46
Default How to implement turbulence in one Solver???
vahid
vahid.najafi is an unknown quantity at this point
Hi Dear Foamers.
I have a big problem!!!!please help me about this!!
my solver is in Appendix.I want to added kinetic turbulence energy in Directory:
OpenFOAM/vahid 2.0.1/run/myinterPhaseChangeFoam/phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.c
in file:SchnerrSauer.c
I have add (turbulence kinetic Energy or k ) in a part of this solver.
first:
added:
-I$(LIB_SRC)/turbulenceModels \
-I$(LIB_SRC)/turbulenceModels/incompressible/RAS/RASModel \
in option.
and then:
added
//.................................................. .....changed
// Construct incompressible turbulence model
autoPtr<incompressible::RASModel> turbulence
incompressible::RASModel::New(U, phi, twoPhaseProperties())
in creatField.
and then:
added
#include "RASModel.H"
and:
volScalarField turbKinEnergy = turbulence().k(); //turbKinEnergy = turbulence().k();
volScalarField turbDisEnergy = turbulence().epsilon();
in this and turbkinEnergy=k
in myinterPhaseChangeFoam.c
and wmake is ok!!!
but
I want in this solver in directory:
I added
in it and:
Foam::tmp<Foam::volScalarField>
Foam:haseChangeTwoPhaseMixtures::SchnerrSauer: Coeff
const volScalarField& p
) const
volScalarField limitedAlpha1(min(max(alpha1_, scalar(0)), scalar(1)));
volScalarField rho
limitedAlpha1*rho1() + (scalar(1) - limitedAlpha1)*rho2()
return
//......I want to change it( <<k>> turbulence multiple in it):
(3*rho1()*rho2())*sqrt(2/(3*rho1()))*k()
*rRb(limitedAlpha1)/(rho*sqrt(mag(p - pSat()) + 0.01*pSat()));
dont successful wmake, and seen(was not declared ):
I/opt/openfoam201/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SchnerrSauer.o
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C: In member function â€کFoam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:haseChangeTwoPhaseMixtures::SchnerrSauer: Coeff(const Foam::volScalarField&) const’:
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:113: error: k() was not declared in this scope
make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Error 1
please help me.
another way that I worked:
) const
volScalarField rho
return
const volScalarField &k=U_.db().lookupObject<volScalarField>("k");
and wmake was Successfully .
but How can I Understand that this k is the same with k(kinetic turbulence energy)???Is it true???
Because I replase another world in this :
const volScalarField &M=U_.db().lookupObject<volScalarField>("M")
but not error occured!!!!!!??????
please help me more about this problem????Thanks.
vahid.najafi is offline   Reply With Quote
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Two equation turbulence models solver settings truffaldino FLUENT 0 March 5, 2011 20:49
Using a user-defined solver in OF ozzythewise OpenFOAM Running, Solving & CFD 3 February 8, 2011 15:28
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 04:24
