Usage of fvm and fvc
Like Tree1Likes
  • 1 Post By dl6tud
Old   July 27, 2012, 07:54
Default Usage of fvm and fvc
Norbert Weber
dl6tud is on a distinguished road
Can anyone help me to understand how to use fvm and fvc?
Here in the forum I found one helpfull thread:
The programmers guide explaines the subject in chapter 2.4. Is says, fvc means a list of values defined at locations in the geometry. It says, fvm are coefficients. Ok.
Let's take an example, the U-equation in piso-Foam:
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
+ turbulence->divDevReff(U)
I already fail with dU/dt. I thought, U is defined for every mesh cell -> at every location -> it must be fvc. But it is not!!! Can someone help me to understand that example?
An other approach
I think, I understand the difference between explicit (fvc) and implicit derivative (fvm). If I have an equation like u=x*x, u can be calculated easily, it is fvc. An implicit equation is the example (2.12) [A][x] = [b]. Back to dU/dt.
I may write dU/dt = u(t)-u(t-1). Explicit. fvc. Wrong. --> How do I know when to use which namespace?
Thanks a lot for your help!
Norbert
granzer likes this.
dl6tud is offline   Reply With Quote
Old   July 27, 2012, 18:28
Norbert Weber
More infos:
Taking an other example, the UEqn from mhdFoam:
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvc::div(phiB, 2.0*DBU*B)
- fvm::laplacian(nu, U)
+ fvc::grad(DBU*magSqr(B))
The velocity U can not be calculated analytically, only by iteration. That means it is implicitely given = fvm.
When calculating U, the field B is kept constant. If it is constant, it may be calculated/readed easily (explicitly) = fvc.
=> So whenever there is a U in the UEqn, I have to write fvm, if it is not fvc. Can someone confirm that or say it better?
Meaning of fvm and fvc JLight OpenFOAM 7 October 13, 2011 11:35
Questions about the fvc and fvm starboy1985 OpenFOAM Programming & Development 0 August 2, 2011 15:52
fvm vs. fvc Pascal_doran OpenFOAM Programming & Development 1 July 8, 2010 15:35
