Home > Forums > OpenFOAM Programming & Development
lookup non included scalars from a list
Old   August 11, 2012, 02:34
Default lookup non included scalars from a list
Hossein
atoof is on a distinguished road
Send a message via Yahoo to atoof
I need to lookup a list from a dictionary composed such as follows:
c_vs_w
100
( 0 0.001)
( 0.01 0.001)
( 0.02 0.001)
( 0.03 0.001)
I want to access to second values of above list by looking up the first values. During the run, it should be looked up non-included scalar from the list (finding corresponding value of 0.015 ,for instance). Can someone suggest me how to do it?
I study different utility and application such as interpolateXY, interpolationTable , etc.
Thank you in advance,
Moha
atoof is offline   Reply With Quote
Old   August 11, 2012, 07:30
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Originally Posted by atoof View Post
c_vs_w
100
( 0 0.001)
( 0.01 0.001)
( 0.02 0.001)
( 0.03 0.001)
Moha
Hello
Your post is not really sufficient for you to get help. I suggest you give more details:
How to give enough info to get help
I think you can take a look at:
tmp<Field<Type> > timeVaryingMappedFixedValueFvPatchField<Type>::interpolate)
in the C++ doc.
Regards
Hisham
Hisham is offline   Reply With Quote
Old   August 13, 2012, 01:05
Hossein
Dear Hisham,
Thanks for reply. Indeed, in my simulation, I obtain a passive scalar (b) by solving a transport equation in a field with a certain U and P. Then I need to interpolate scalars from a table as a source term (W) by the value of "b" and send it to a solver. This lookup table consists of lists such as
100
(b1 w1)
(b2 w2)
(b3 w3)
(b4 w4)
I need to reach a "W" which is corresponding with a "b". My question is "How can this procedure be done?".
I studied timeVaryingMappedFixedValueFvPatchField but I don't know how to use it. I think this function in used for boundary condition. But I should find the source term in my entire field.
Best Regards
Hossein
Old   August 13, 2012, 06:03
Hisham's Avatar
Hisham Elsafti
Dear Hossein,
I do not really know if such a possibility is actually available in OpenFOAM. I am sure someone must have implemented it before. The available interpolations are time interpolations or space interpolations over the mesh.
Nevertheless, introducing interpolation to the code in your case should not be difficult.
I think it may be interesting to take a look at other libraries for interpolation (to link to your solver):
gsl: http://www.gnu.org/software/gsl/
http://www.gnu.org/software/gsl/manu...rpolation.html
CGAL: http://www.cgal.org/Manual/latest/do...:Interpolation
A more careful search can yield better (more convenient) options.
Regards
Hisham
Old   August 13, 2012, 08:14
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Hossein
You should be able to do something in the following way, where I assume you have the b and w coefficients as two scalarFields (the code below has not been tested).
// scalarField B = <KNOWN>
// scalarField W = <KNOWN>
// Your parameter b-simulation
scalar bSim(<some value>);
// Your source term w-simulation
scalar wSim( Foam::interpolateXY( bSim, B, W ) );
interpolateXY is a function and not an object, which I why you cannot construct it.
Furthermore, remember to include the following in your files:
#include "interpolateXY.H"
Please note that this yields a linear interpolation. If you need other types (higher order) interpolation scheme, then I am not sure if it is readably available in OF.
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   August 14, 2012, 01:19
Hossein
Thanks Niels,
It seems that I can implement it my code. I test it asp.
But I have a file contains a list which includes both "b" and "w" such as my previous post. how can I define this list(of list) and access to it's member.
Best Regards,
Hossein
Old   August 14, 2012, 02:25
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hey,
are the lists of the same size as your mesh?
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   August 15, 2012, 07:21
Hossein
Hello Kathrin,
Not necessarily. In my code, it has 100 members.
Sincerely yours,
Hossein
Old   August 16, 2012, 16:53
Hossein
Dears,
I read some other posts such as:
Interpolation using interpolationLookUpTable or interpolationTable classes
But I do not know the format of input files (X,Y,Xi in above code) to the code? and how can I read them through the code?
Hossein
Old   September 3, 2012, 07:31
Default Solved
Hossein
Dears,
Finally we find the solution. We Used the following for reeding scalars from two lists in a dictionary.
    IOobject dictHdr
                    "listTestDict",
                    runTime.system(),
                    mesh,
                    IOobject::MUST_READ,
                    IOobject::NO_WRITE
    IOdictionary dict(dictHdr);
    List<scalar> X(dict.lookup("X"));
    List<scalar> Y(dict.lookup("Y"));
Thread Tools
Trackbacks are On
swak4foam building problem GGerber OpenFOAM Installation 54 April 24, 2015 16:02
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 01:52
Convergence on anisotropic tetahedral meshes pbo OpenFOAM Running, Solving & CFD 12 December 14, 2010 12:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
