November 7, 2019, 06:42 |
undefined symbol error
Ian
Rep Power: 7 |
Hi everyone
Recently, I developed a new class named ControllerStateProvider in the src fold and use the allwmake to compile it and there is no error. After that, I modify the rigidbodyState (a function object to get the state of moving body) and add several lines about the ControllerStateProvider class , and I have modify the option of the rigidbodyState, just like this Code:
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/dynamicMesh/lnInclude \ -I$(LIB_SRC)/dynamicFvMesh/lnInclude \ -I$(LIB_SRC)/ControllerStateProvider/lnInclude \ -I$(LIB_SRC)/rigidBodyDynamics/lnInclude \ -I$(LIB_SRC)/rigidBodyMeshMotion/lnInclude \ -I$(LIB_SRC)/OpenFOAM/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude LIB_LIBS = \ -lfiniteVolume \ -lmeshTools \ -L $(FOAM_LIBBIN) \ -L $(FOAM_USER_LIBBIN) \ -lControllerStateProvider \ -ldynamicFvMesh \ but when I run a test case which use the interDyMFoam, it shows warning just like this Code:
--> FOAM Warning : From function void* Foam::dlOpen(const Foam::fileName&, bool) in file POSIX.C at line 1604 dlopen error : /home/ian/OpenFOAM/ian-v1712/platforms/linux64GccDPInt32Opt/lib/librigidBodyState.so: undefined symbol: _ZN4Foam23ControllerStateProvider8positionE --> FOAM Warning : From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 105 could not load "librigidBodyState.so" --> FOAM Warning : From function bool Foam::dlLibraryTable::open(const Foam::dictionary&, const Foam::word&, const TablePtr&) [with TablePtr = Foam::HashTable<Foam::autoPtr<Foam::functionObject> (*)(const Foam::word&, const Foam::Time&, const Foam::dictionary&), Foam::word, Foam::string::hash>*] in file lnInclude/dlLibraryTableTemplates.C at line 62 Could not open library "librigidBodyState.so" Could anyone offer some advice? It will be much appreciated! |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
