February 19, 2015, 17:07 |
Old and new values of a field
Rep Power: 11 |
Hi, I have a problem with using old value of a field.
I have A and B - dimensionless volScalarFields I also have Code:
dimensionedScalar c ("c", dimensionSet(0, 0, 1, 0, 0, 0 ,0), 1.0); I want to solve two equations below in OpenFOAM (n - number of time layer): 1) ; 2) (I want to find from the first equation and then from the second one) I used this code with Euler scheme: Code:
A = 2*B; fvScalarMatrix BEqn ( c*fvm::ddt(A,B) + fvm::Sp(1,B) ); BEqn.solve(); Code:
A = 2*B And I got the wrong decision! What code will solve equation and won't delete old values? Thank you very much for any help ... |
February 24, 2015, 06:42 |
simple equation
Rep Power: 11 |
February 27, 2015, 04:06 |
anonymous
Rep Power: 12 |
Are you going to use always that kind of temporal discretization? If the answer is yes, you can access runTime delta T:
dimensionedScalar mydeltaT1("mydeltaT",dimensionSet(0, 0, 1, 0, 0, 0, 0),scalar(runTime.deltaTValue())); |
